Old 10-20-2015, 05:22 PM   #575
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by Shit Luck View Post
I am on the original stuff...
Shoot me an email with the address you want it shipped to and ill get those out to you in the next few days
JDLAutoDesign is offline   Reply With Quote
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
Kris86 (10-27-2016), Shit Luck (10-20-2015)
Old 10-20-2015, 06:04 PM   #576
Shit Luck
Drives: red frs
Sent one to the info@jdl account
Shit Luck is offline   Reply With Quote
Old 10-21-2015, 06:04 AM   #577
Airtreking
Drives: GT86 Limited
Originally Posted by blueap2 View Post
@JDLAutoDesign
any news of fitment with washer bottle?
I know a couple of guys are looking for a solution with the CAI. I couldn't wait any longer so I bought the Ptuning washer bottle, everything fits fine, just working out the best way to route the hose, if they have a bottle with the nozzle on the other end that would be perfect.
Airtreking is offline   Reply With Quote
The Following User Says Thank You to Airtreking For This Useful Post:
xxscaxx (10-21-2015)
Old 10-21-2015, 12:58 PM   #578
xxscaxx
Drives: 2013 SWP BRZ
Nice! I may look into that.
xxscaxx is offline   Reply With Quote
Old 10-21-2015, 04:54 PM   #579
Shit Luck
Drives: red frs
I was going to hack up a headlight like evasive did over the winter...
This maybe easier.
Old 10-21-2015, 10:18 PM   #580
nelsmar
This maybe easier.
Your concerned about a washer bottle but removed your ac??? lol
I never used my sprayers... When I took the bottle out and it was at the full line. >.<
My flickr - Canibeat
Local magazine scout
Old 10-21-2015, 10:32 PM   #581
Shit Luck
Drives: red frs
Not really, can't remember the last time I used it, but it one of those things they can hassle me on at inspection time.
Old 10-22-2015, 11:27 AM   #582
nelsmar
Ah... I forget about inspection at times. We don't have that sort of thing in Arizona. They simply check your gas cap & use an OBD scan for readiness... lol
Old 10-23-2015, 10:34 AM   #583
ofuts
Drives: 2013 Toyota 86 MT
Hi
I have serious oil temp problem now that i want to solve asap. I can not track my car right now, and i booked track days for 3 days back to back, today tomorrow and sunday, please help me solve the problem.
I had been running JDL turbo kit (GTX2867R turbo) for about 3 weeks now, had oil temperature problems immediately, never went below 120C, around 125-130 when boosting, so i installed HKS oil cooler (and koyo radiator for peace of mind), took out the fog lights and duct one extra pipe to oil cooler from the front grill near intercooler, i olso titanium wrapped headers, downpipe and overpipe, and olso have a turbo blanket. Now i am seeing around 105-110C when cruising around 120km/h, 100-105 when cruising around 90km/h 6th gear on highway, very quickly climbs up to 115-120C in one minute boosting around 90-180 km/h, 120-125C in city traffic, ambient temperatures are around 20C.
Took the car to track today, i started at 90C oil temp, just like i imagined i did 3 laps (one lap is around 1:25) at 70-80% pace and oil temp was 130C!!! Did 3 cooldown laps and it dropped 120C. Took less than 2 laps to hit 130C and took 3 laps to cool it down to 120C again. It is like a joke, not fun spending 2/3rd of my time doing cooldown laps and can not concentrate because i am constantly checking temps when i do normal a lap.
Did not have any problems with water temps though. Ambient temps are around 22C. I am using Motul 0W40.
I think these numbers are not normal.
What do you think can be wrong, where should i check?
I was worried if there was sth wrong about water cooling, checked water lines to turbo, they go to correct direction according to JDL installation guide, but it has no details at all so can not be sure about T links.
Thanks
ofuts is offline   Reply With Quote
Old 10-23-2015, 11:44 AM   #584
nelsmar
Originally Posted by ofuts View Post
Hi
Thanks
How are you measuring oil temp? Are you using the OEM sensor and logging via CANBUS? Or did you install an actual gauge? Also did you add the coolant lines to the turbo?
Old 10-23-2015, 12:22 PM   #585
ofuts
I use innovate mtx-d oil pressure/temperature gauge, sensors are at sandwich plate, sandwich plate came with HKS oil cooler kit.
I am planning to connect another temp sensor tomorrow and compare. but i guess they will show same values.
Yes, i connected coolant lines, bottom one goes to left side (facing the engine from front of the car) and top one to the right side at engine connection. Is there any specific t-line order for these pipes?
Old 10-23-2015, 04:21 PM   #586
ofuts
First 2 pictures are cold line and second 2 are hot.
So i am guessing that there shouldn't be t-links and lines should connect directly for proper flow but there are 4 holes, 2 holes will be left open if directly connected.
Can someone guide me here please, pictures of correct way would be very helpful.
Old 10-24-2015, 01:16 PM   #587
ofuts
Ok, i think it is my innovate mtx-d oil gauge, it is reading too high. Took out its temp sensor and replaced with greddy gauge, compared both simultaneously, innovate was reading 10C higher. Not sure if it the sensor or gauge becouse greddy sensor cable was not compatible with innovate.
Old 10-25-2015, 07:33 AM   #588
ofuts
Just came into my mind that one sensor port is closer to the oil line going "to" the oil cooler and other one is closer to the line "from" the oil cooler, can that be the reason i got 10C difference?
(HKS oil cooler comes with a thermostatic sandwich plate)
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
