06-11-2022, 10:32 AM | #2157 |
Drives: 2018 Subaru BRZ
Might’ve found the issue. Needs some grease. Probably a bleed too to be in the safe side.
The Following User Says Thank You to spcmafia For This Useful Post: | Spuds (06-11-2022) |
06-11-2022, 12:09 PM | #2158 |
The Dictater
Drives: '13 Red Scion FRS
06-11-2022, 01:49 PM | #2159 | |
義理チョコ
06-11-2022, 04:07 PM | #2161 |
義理チョコ
As long as it keeps working but waiting until hearing it creak means making that shoulder a little taller every time you push the pedal.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (06-11-2022) |
06-11-2022, 05:40 PM | #2162 |
Did a bleed and grease. Might need to take the thing apart and clean it really well. Also did a bleed and there was some dark stuff inside the fluid. Very murky.
The Following User Says Thank You to spcmafia For This Useful Post: | humfrz (06-11-2022) |
06-11-2022, 08:26 PM | #2163 |
Persona Non Grata
Drives: '15 BRZ (WRB)
If I were going to pull the transmission, I'd full monty it and replace the bearing and the fork and the pivot with Verus replacements. Sometime over the summer I'm going to order a fork/pivot/bearing set to add to my "when-not-if" box.
Slow is smooth, and smooth is fast
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
06-11-2022, 08:40 PM | #2164 |
Site Moderator
Drives: ichi 86 Project
You also wanna change the bearing retainer (#30099AA040). Not often, but those things can cause the bearing to get stuck
The Following User Says Thank You to ichitaka05 For This Useful Post: | Capt Spaulding (06-12-2022) |
06-11-2022, 10:06 PM | #2165 | |
ProCrastinationConsultant
been driving the truck too much lately apparently, took the car out for a drive today, and had a minor freak out for the first 5 miles while i could feel the engine vibrations through the clutch pedal-- same typical vibrations at the gear shift knob...
06-11-2022, 11:35 PM | #2166 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (06-11-2022), Spuds (06-12-2022) |
06-11-2022, 11:57 PM | #2167 |
apparently, it's impossible to find gif's anymore.. everything's moving to video...
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (06-12-2022) |
06-12-2022, 03:06 AM | #2168 |
Because compromise ®
Drives: Red Herring
Intoxicated.
I'm not suggesting this is a bad thing.
The Following User Says Thank You to Captain Snooze For This Useful Post: | humfrz (06-12-2022) |
06-12-2022, 09:58 AM | #2169 |
it's only bad while hiking in hilly terrain, driving, walking in public, and family events before you're expected to make a large solemn speech.
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Capt Spaulding (06-12-2022), Captain Snooze (06-12-2022) |
06-12-2022, 11:28 AM | #2170 |
The Dictater
The Following User Says Thank You to Spuds For This Useful Post: | Captain Snooze (06-12-2022) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
