Old 06-11-2022, 10:32 AM   #2157
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Might’ve found the issue. Needs some grease. Probably a bleed too to be in the safe side.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Spuds (06-11-2022)
Old 06-11-2022, 12:09 PM   #2158
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes, mine does the same thing.
Old 06-11-2022, 01:49 PM   #2159
https://www.reddit.com/r/ft86/comments/v9ylu4/normal_squeal/?utm_source=share&utm_medium=ios_app&utm_name=ioss mf
Here’s what it usually sounds like. Didn’t do the same thing as yesterday.
I don’t feel any difference in pressure and gear engagement is fine.
That's typical. I thought you felt and heard the bearing wobble while the pedal was at the floor. Grease will help for a while but the fork will need to be replaced or the main socket carefully re-shaped with a dremel.
Old 06-11-2022, 04:02 PM   #2160
Spuds
The Dictater
Spuds's Avatar
Grease is cheap and easy though, so...
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (06-11-2022)
Old 06-11-2022, 04:07 PM   #2161
As long as it keeps working but waiting until hearing it creak means making that shoulder a little taller every time you push the pedal.
Spuds (06-11-2022)
Old 06-11-2022, 05:40 PM   #2162
spcmafia
spcmafia's Avatar
Did a bleed and grease. Might need to take the thing apart and clean it really well. Also did a bleed and there was some dark stuff inside the fluid. Very murky.
humfrz (06-11-2022)
Old 06-11-2022, 08:26 PM   #2163
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If I were going to pull the transmission, I'd full monty it and replace the bearing and the fork and the pivot with Verus replacements. Sometime over the summer I'm going to order a fork/pivot/bearing set to add to my "when-not-if" box.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
humfrz (06-11-2022), soundman98 (06-11-2022), Ultramaroon (06-11-2022)
Old 06-11-2022, 08:40 PM   #2164
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
You also wanna change the bearing retainer (#30099AA040). Not often, but those things can cause the bearing to get stuck
Capt Spaulding (06-12-2022)
Old 06-11-2022, 10:06 PM   #2165
soundman98
ProCrastinationConsultant
soundman98's Avatar
on my list as well.
been driving the truck too much lately apparently, took the car out for a drive today, and had a minor freak out for the first 5 miles while i could feel the engine vibrations through the clutch pedal-- same typical vibrations at the gear shift knob...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
2020BRZtS (06-11-2022), Spuds (06-11-2022)
Old 06-11-2022, 11:35 PM   #2166
Bubba approves of that post -
(why fix it if you can repair it - Bubba)
soundman98 (06-11-2022), Spuds (06-12-2022)
Old 06-11-2022, 11:57 PM   #2167
soundman98
soundman98's Avatar
apparently, it's impossible to find gif's anymore.. everything's moving to video...
humfrz (06-12-2022)
Old 06-12-2022, 03:06 AM   #2168
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Intoxicated.
I'm not suggesting this is a bad thing.
humfrz (06-12-2022)
Old 06-12-2022, 09:58 AM   #2169
soundman98
soundman98's Avatar
it's only bad while hiking in hilly terrain, driving, walking in public, and family events before you're expected to make a large solemn speech.
Capt Spaulding (06-12-2022), Captain Snooze (06-12-2022)
Old 06-12-2022, 11:28 AM   #2170
Spuds
The Dictater
Spuds's Avatar
Or at work.
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
