Old 02-01-2019, 03:33 PM   #43
86MLR
86MLR's Avatar
What's you guys opinions on the Stance solid bushing inserts vs the poly(or whatever) Whiteline style bushing inserts? Probably more NVH but less give right? I'm LS swapping so stiffening the diff/subframe seemed wise
Unless it's a race car, living with solid bushings can be painful.
My 86 with subframe and diff support inserts has enough NVH to annoy the missus that she wants the windows down if we go for a drive, even when its 35!° C.
Noise mainly, some vibrations at certain RPM's.
75% of my noise comes from the Whiteline diff inserts.
The added NVH from inserts doesn't bother me "much" though.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 02-01-2019, 03:47 PM   #44
Ashikabi
Ashikabi's Avatar
Well the Stance inserts aren't full replacement bushings. They appear to be a billet version of the Whiteline inserts
Old 02-09-2019, 05:07 PM   #45
JIM THEO
Drives: BRZ 2018
I installed finally the tS >16 lower stoppers with tS longer bolts in all four subframe corners.
Car seems little bit more predictable when sliding or during weight transfer on continuous corners, imho it should have them from the factory.
No NVH increase, may be due to stiffened rear end it is more comfort now but the difference is tiny anyway.
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
nikitopo (02-09-2019)
Old 02-10-2019, 03:56 AM   #46
gpvecchi
gpvecchi's Avatar
All 4? Shouldn't they go in front only?
gpvecchi is offline   Reply With Quote
Old 02-10-2019, 04:10 AM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There were some reviews in the past that the fronts do most of the work, but I'm thinking now that it is best to install all 4. You should get a bit more improvement with the rears. It looks that STI installed only the fronts to keep the cost lower. Not so much because of the additional cost of the part, but the additional installation work. I remember to pay more for labor than the parts when I installed the front in my car. Normally you don't remove completely the subframe, so I guess you need extra time if you do both front the rear.
Old 02-11-2019, 04:28 PM   #48
JIM THEO
Drives: BRZ 2018
If you do one by one you only need to jack up each subframe corner when you install the new longer bolt, simply take off the old and install the new BY HAND.
Old 02-11-2019, 06:22 PM   #49
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
Has anyone mentioned the spoon rigid collars yet? I plan on doing those in conjunction with the WL subframe inserts.
Spoon has a cool video explaining how the rigid collars work, but in short, they help mate the irregular surfaces of the subframe and chassis together. Manufacturing processes don't allow perfect mating surfaces between the subframe and chassis, and these are supposed to fill in that area making the mounting points completely flush. This supposedly equates to a whole bunch of handling goodness
https://www.spoonsports.eu/50261-na1-001.html
Some of the speedhunter guys have them on their cars as well.
http://www.speedhunters.com/2018/01/...-honda-heaven/
http://www.speedhunters.com/2011/06/...s_to_the_gt_r/
JCW 86 is offline   Reply With Quote
Old 02-12-2019, 02:10 AM   #50
JIM THEO
Drives: BRZ 2018
STI subframe bolts (from tS) do the same, they are wider/longer and close the gap so there is no horizontal movement of the subframe, along with the upper or lower stoppers (upper work on compression lower on extension) they improve the overall feeling of the rear when cornering.
See yourself the difference between the tow bolts:
Old 02-13-2019, 07:42 PM   #51
15limited
15limited's Avatar
Huh, interesting. So the "TS" bolts are different dimensionally, and still work?!
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-14-2019, 01:47 PM   #52
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I'm really interested in some thoughts from the group on this topic. I am planning to do something relatively soon, and I'm split on whether I should run Spoon rigid collars, or if I should go for full solid bushings like those from SPL, or if I should do bushing topper inserts like the Whiteline ones for my subframe. I really want to reduce subframe slop, because as I've gotten stickier tires it's more and more obvious how much the body moves.
What's the consensus on the best solution that isn't going to absolutely torture me if I happen to drive on a rough road (which is unfortunately all over the place here in SATX)?
Tristor is offline   Reply With Quote
Old 02-14-2019, 06:28 PM   #53
15limited
15limited's Avatar
Daily driver? It all comes down to you, man. How hardcore are you? I drove solid subframe and diff mount along with all kinds of other "track" parts a hundred or so miles everyday for months. Some of my friends hate how loud the exaust is in the car, or how much vibration there can be while driving, harsh bumps. And I completely understand why, but they're also just a passenger, they dont feel the wheel in their hands, or how the car moves under you. All essentially useless when you're sitting in your commute. The largest noticeable differences for me was how quick the rear responded to hard throttle/clutch kicks, cured wheel hop and quick direction change stability.
The Following User Says Thank You to 15limited For This Useful Post:
Tristor (02-27-2019)
Old 02-27-2019, 09:02 PM   #54
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I installed PBM solid diff/subrame mounts about 3 years ago, there is a bit of noise, kinda sounds like there is a supercharger in my boot... But it's just to much nicer with them in there, rear end feels much more solid.
I have sound deadened my boot, which helped with noise (and got rid of exhaust drone)
My car is my work car, so i put on a fair few km's, and had done drives from Melb to Canberra and the noise doesn't worry me.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
15limited (02-27-2019)
Sold 86TOYO2k17 Transmission and Driveline 9 03-28-2020 02:00 PM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 11:24 AM
FS: SuperPro subframe inserts & LCA inner bushings xn7485 Brakes, Suspension, Chassis 1 09-13-2017 03:23 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 09:20 PM
