Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-26-2017, 11:59 PM | #1 |
Drives: 2014 BRZ Limited 6MT
Lowered and axles
I have read in a few places where lowering the car weakens the rear axles. I am about to start my suspension build and need to know a safe distance I can lower the car without worrying about hurting the rear axles. Something about the angle from being lower makes them weaker. I am also making double the stock cars hp so that's a factor too, the last thing I need is to stress them more. Anyone very knowledgeable on this specifically?
06-27-2017, 02:47 AM | #2 |
Off Topic
Going lower than about an inch stresses the cv joint. The stance crowd has parts specifically to raise the subframe and bring the axles back to a somewhat normal angle. That said, plenty of people run 1-1.5 inches down with no issues.
06-27-2017, 02:50 AM | #3 |
Drives: 2014 GT86
It's more about angle of connection of axle with diff. If one goes overboard with lowering, worth installing some diff riser for angle to get shallower, to lessen load of work joint has to do per each turn.
Also, it's not just about rear .. if one cares also about handling, worth searching about roll center adjusting to fix some handling issues overlowering introduces. And stiffer suspension. And .. BUT! That all is not much of an issue .. if one lowers at reasonable extent, eg. <1". Also you'll keep this way more practicality/compliance/drivability/comfort for daily driving. (for example, worth installing much stiffer springs to compensate overlowered suspension bumpless travel. So for not going overboard your spine will thank you for not making car undriveably harsh). |
The Following User Says Thank You to churchx For This Useful Post: | smg1138 (06-28-2017) |
06-27-2017, 03:09 AM | #4 | |
Time Traveller
@tofurun
I've covered this in quite a few posts. -1.2" or less = generally safe -1.5" = rolling the dice -1.6" or more = trouble, especially if running improved power. PartsShopMax has what you need for $100. Install likely needs a professional. https://store.partsshopmax.com/shop/...s/ZNC6SDR.html Quote:
The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | gramicci101 (06-27-2017), smg1138 (06-27-2017) |
06-27-2017, 11:02 AM | #5 |
It also depends on how much camber you're running, more camber in the rear increases the angle the outer CV joint has to work through.
06-27-2017, 11:14 AM | #6 |
Drives: 2013 Raven FR-S
06-27-2017, 11:15 AM | #7 |
Drives: Honda Accord Euro
Does anybody do diff risers that are "the same" or similar like OEM in terms of NVH? I would like to do +20mm but OEM style.
06-27-2017, 01:25 PM | #8 |
It'll depend on ride height as well. What ultimately does the damage is the angle the CV joint is working at. Being lower increases it, but so does camber.
06-27-2017, 03:25 PM | #9 |
Time Traveller
09-15-2023, 07:37 AM | #10 | ||
I plan on lowering aorund 1,2-1,5 inch so maybe at the limit. I want to track the car often (NA) and I wonder if do I really need the risers Quote:
https://www.cspracing.com/whiteline-...ing/wl-kdt924/ I presume you can raise the diff because there are 3 holes but not sure. PSM kit has other parts too |
09-15-2023, 12:38 PM | #11 | |
Drives: Crapcan
Also keep in mind raising the subframe height increases anti squat which will have a negative effect on putting down power. We already have too much anti squat in the rear suspension geometry. SPL documents this in their installation instructions. https://www.splparts.com/products/fr...-bushings.html
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
09-18-2023, 01:46 PM | #12 | |
it would be so helpful if those who did have CV issues can share their ride height about anti squat, I had no idea about that... good to know! however I would only raise the differential, so I believe it should remain the same edit: well I just found this post... will be super helpful https://www.ft86club.com/forums/showthread.php?t=49511 Last edited by J95; 09-18-2023 at 01:58 PM. |
The Following User Says Thank You to J95 For This Useful Post: | NoHaveMSG (09-18-2023) |
09-18-2023, 03:16 PM | #13 |
Drives: Crapcan
If you could that would be great. You may need to have some custom solid rear bushings for the diff to do it. Really going to have to measure the pinion angles and see what is possible.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | J95 (09-18-2023) |
09-18-2023, 05:53 PM | #14 | |
https://store.partsshopmax.com/ZNC6SDR.html |
Similar Threads | ||||
WTB: 600 hp axles | ft86me | Want-To-Buy Requests | 0 | 05-02-2017 07:40 PM |
WTB: Axles | RavioliG | Want-To-Buy Requests | 0 | 03-08-2017 06:18 PM |
Possible bad axles? | Phothiraj | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-05-2016 11:10 PM |
Axles | D K | Engine, Exhaust, Transmission | 4 | 06-27-2016 10:38 AM |
DSS Axles? | nickmerronesucks | Want-To-Buy Requests | 6 | 02-01-2016 08:09 AM |
