Old 06-26-2017, 11:59 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Lowered and axles
I have read in a few places where lowering the car weakens the rear axles. I am about to start my suspension build and need to know a safe distance I can lower the car without worrying about hurting the rear axles. Something about the angle from being lower makes them weaker. I am also making double the stock cars hp so that's a factor too, the last thing I need is to stress them more. Anyone very knowledgeable on this specifically?
tofurun is offline   Reply With Quote
Old 06-27-2017, 02:47 AM   #2
gramicci101
Off Topic
Going lower than about an inch stresses the cv joint. The stance crowd has parts specifically to raise the subframe and bring the axles back to a somewhat normal angle. That said, plenty of people run 1-1.5 inches down with no issues.
Old 06-27-2017, 02:50 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
It's more about angle of connection of axle with diff. If one goes overboard with lowering, worth installing some diff riser for angle to get shallower, to lessen load of work joint has to do per each turn.
Also, it's not just about rear .. if one cares also about handling, worth searching about roll center adjusting to fix some handling issues overlowering introduces.
And stiffer suspension.
And ..
BUT! That all is not much of an issue .. if one lowers at reasonable extent, eg. <1". Also you'll keep this way more practicality/compliance/drivability/comfort for daily driving. (for example, worth installing much stiffer springs to compensate overlowered suspension bumpless travel. So for not going overboard your spine will thank you for not making car undriveably harsh).
Old 06-27-2017, 03:09 AM   #4
DAEMANO
Time Traveller
@tofurun
I've covered this in quite a few posts.
-1.2" or less = generally safe
-1.5" = rolling the dice
-1.6" or more = trouble, especially if running improved power.
PartsShopMax has what you need for $100. Install likely needs a professional.
https://store.partsshopmax.com/shop/...s/ZNC6SDR.html
FRS / BRZ Solid Diff Riser
The axle angle is so bad when this car is lowered that it puts a lot of strain on the axle joints. This bushing set eases the angle of the axles on lowered cars by raising the diff 20mm. Bolt on CNC aluminum gold anodized front bushings and Weld on laser cut steel subframe/rear diff mounts with new hardware. The FRS and BRZ use a lexus diff and also the luxury oil filled rubber mounts that are great for canceling a lot of noise, vibration, and harshness from the luxury car but they are doing you a disservice getting the power to the ground in your sports car. CLICK HERE to jump to the forum to see our installation example.
Old 06-27-2017, 11:02 AM   #5
wparsons
wparsons's Avatar
It also depends on how much camber you're running, more camber in the rear increases the angle the outer CV joint has to work through.
flickr
Old 06-27-2017, 11:14 AM   #6
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
How much negative camber can damage the CV joint? I generally run about -2 in the rear.
smg1138 is offline   Reply With Quote
Old 06-27-2017, 11:15 AM   #7
JDM4E
Drives: Honda Accord Euro
Does anybody do diff risers that are "the same" or similar like OEM in terms of NVH? I would like to do +20mm but OEM style.
JDM4E is offline   Reply With Quote
Old 06-27-2017, 01:25 PM   #8
wparsons
wparsons's Avatar
It'll depend on ride height as well. What ultimately does the damage is the angle the CV joint is working at. Being lower increases it, but so does camber.
flickr
Old 06-27-2017, 03:25 PM   #9
DAEMANO
Time Traveller
I know there is another company making them (Whiteline I think or perhaps or Cusco) unsure if they're soft or solid.
Old 09-15-2023, 07:37 AM   #10
J95
J95's Avatar
Originally Posted by DAEMANO View Post
@tofurun
Is there any updated info about this? Lately I am reading a lot about people breaking axles but I am unsure about the amount of drop that causes it
I plan on lowering aorund 1,2-1,5 inch so maybe at the limit. I want to track the car often (NA) and I wonder if do I really need the risers
can you tell if you mean this one?
https://www.cspracing.com/whiteline-...ing/wl-kdt924/
I presume you can raise the diff because there are 3 holes but not sure. PSM kit has other parts too
J95 is offline   Reply With Quote
Old 09-15-2023, 12:38 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have been running around -1.5 on my car for a long time, FBO with flex fuel, tons of track days, no CV issues.
Also keep in mind raising the subframe height increases anti squat which will have a negative effect on putting down power. We already have too much anti squat in the rear suspension geometry. SPL documents this in their installation instructions.
https://www.splparts.com/products/fr...-bushings.html
Old 09-18-2023, 01:46 PM   #12
J95
J95's Avatar
that sounds good, thanks for sharing the experience
it would be so helpful if those who did have CV issues can share their ride height
about anti squat, I had no idea about that... good to know! however I would only raise the differential, so I believe it should remain the same
edit: well I just found this post... will be super helpful
https://www.ft86club.com/forums/showthread.php?t=49511
Old 09-18-2023, 03:16 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you could that would be great. You may need to have some custom solid rear bushings for the diff to do it. Really going to have to measure the pinion angles and see what is possible.
Old 09-18-2023, 05:53 PM   #14
J95
J95's Avatar
its possible with these parts
https://store.partsshopmax.com/ZNC6SDR.html
WTB: 600 hp axles ft86me Want-To-Buy Requests 0 05-02-2017 07:40 PM
WTB: Axles RavioliG Want-To-Buy Requests 0 03-08-2017 06:18 PM
Possible bad axles? Phothiraj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-05-2016 11:10 PM
Axles D K Engine, Exhaust, Transmission 4 06-27-2016 10:38 AM
DSS Axles? nickmerronesucks Want-To-Buy Requests 6 02-01-2016 08:09 AM
