12-06-2021, 10:24 PM | #99 |
Drives: 2022 GR86
12-07-2021, 08:51 AM | #101 | |
TRACKBREAD
Tire fitment issues in the rear
Eh, tire rack is so conservative with offsets they won’t recommend anything more than a few 5mm away from stock in my experience. The offset on a set of OZs they recommended for my Audi were actually 2mm less aggressive than stock. |
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | DocWalt (12-07-2021), OkieSnuffBox (12-07-2021) |
12-07-2021, 09:12 AM | #102 | |
Drives: 1996 Turbo Miata
12-07-2021, 09:23 AM | #103 |
Drives: '22 BRZ
Not really a big deal, it's super easy to run spacers up front and just have wheels with the same offset all around. Not as easy since now you need extended studs but there are kits to get it all at once.
12-07-2021, 09:23 AM | #104 |
Drives: '22 BRZ Limited 6MT
12-07-2021, 10:10 AM | #105 | ||
I agree it's not a huge deal, just have to get hub centric spacers. I didn't like the ideal of a wider front track width, but another poster mentioned the front is narrower. |
12-07-2021, 10:28 AM | #106 | |
Drives: '23 BRZ Limited
Still a bummer that they would give less room out back for a wheel/tire combo than the 1st gen. |
12-07-2021, 03:02 PM | #107 |
Drives: 2022 GR86
Looks like 255/35R18 tires on 18x9.5 et45's can be squeezed in, with a bunch of camber. Might be the most aggressive fitment (wrt the outside of the tire) that still works:
12-07-2021, 03:53 PM | #108 |
Drives: Too fast
The Following 2 Users Say Thank You to dsc_pat For This Useful Post: | OkieSnuffBox (12-07-2021), Pete (12-07-2021) |
12-07-2021, 05:03 PM | #109 | |
I'm curious to see how much room can be gained with just a roll, not a roll and pull. Of course, even with just a roll you can risk cracking the paint. |
12-07-2021, 05:41 PM | #110 |
Drives: On order: 2022 ISM BRZ Ltd
Those wheels look really nice, and just about perfect offset in relation to the fenders. Could maybe go a little wider with the rubber to reduce the chance of curb rash.
The Following User Says Thank You to slipstream8 For This Useful Post: | timurrrr (12-07-2021) |
12-07-2021, 05:51 PM | #111 |
Drives: '22 WRB
I think with something less wide than the Yokohamas A052's, you could run this setup on stock camber in the back. My 255/40/17 Yoks are pinched pretty good on the 9" wheels.
12-07-2021, 05:54 PM | #112 |
Drives: 2022 GR86
Maybe just a couple of mm more than I'd want to.
The perfect flush fitment of the wheel at ride height sure looks nice, but isn't necessarily the best option when the suspension can move. As highlighted in other pics on this thread, there's a badly placed bump in the fender liner that the tire needs to avoid when the suspension is compressed. Yup, looks like too much rear camber for the track indeed. But not enough to be qualified as stance yet, I guess. |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
