04-10-2022, 07:05 PM | #11145 | |
Sent from my IN2017 using Tapatalk |
The Following User Says Thank You to BlOody_BoOger For This Useful Post: | Qwimby1 (04-10-2022) |
04-10-2022, 08:22 PM | #11146 | |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
04-10-2022, 08:37 PM | #11147 |
04-17-2022, 02:14 PM | #11148 |
Drives: black frs
If anyone is interested I'm fixing to list my phantom supercharger 2.5 with proceed controller.
05-15-2022, 12:06 PM | #11149 |
No boost
It quit boosting about a month ago and I didn't have time to go after the problem, which may well be that solenoid hose that was mentioned at the time. When that happened, I could get it to spin by activating the throttle switch with the engine off. Since I had no time to work on it, I switched it off and have driven it that way for a month. Now something else is happening. When I try to get it to spin with motor off, it only starts to spin for about a second and quits. Once it spun for about 3 seconds and quit. I'm showing 28.3 volts. I planned to take it to my wrench and let him find the boost leak, but now this new problem. Does anyone know what might be going on now?
05-16-2022, 04:50 PM | #11150 |
I sure hope one of you guys with more knowledge of these has some info. I'm all out of ideas.
05-18-2022, 12:53 PM | #11151 |
No boost, no spin
I unhooked the compressor enough to hand spin it and it seems to turn OK, although I can feel some resistance at certain points in the revolution. I think it was like that before I installed and it worked OK. When I activate the throttle switch it just starts to spin and quits. Volts drop from 28.3 to 25+ very briefly and then back to 28.3. I'm assuming the dump batteries are charged because of the voltage reading, but could it be that after no use for a month they have lost enough charge to create this problem? I drove it most of a month with the system turned off, but did have it on for a while. They should be getting a charge. It's getting a signal from the controller because it does try to spin for just a moment. I'm at a loss to figure it out.
05-18-2022, 02:42 PM | #11152 | |
05-18-2022, 03:17 PM | #11153 | |
Thanks, I'll make that my next step. Starter battery has 12.79. I have to take off some stuff to get to the dump batteries. |
06-03-2022, 03:01 PM | #11154 |
I finally had a chance to get in there and didn't have to look too far. One ETX16 dump battery is holding 12.83V, the other 11.77.
I'll order a new pair. |
06-04-2022, 07:35 AM | #11155 |
Drives: FR-S,GTI
It's almost always the batteries.
They only last a couple years but are pretty cheap. I change them every couple years regardless. |
The Following User Says Thank You to WNDSRFR For This Useful Post: | Qwimby1 (06-05-2022) |
06-04-2022, 07:35 AM | #11156 |
Drives: FR-S,GTI
06-04-2022, 07:46 AM | #11157 |
Drives: FR-S,GTI
What battery tray are you using?
I still use the original 1.5 tray with the Powersonic batteries. About 40 bucks apiece. |
06-04-2022, 07:46 AM | #11158 |
Drives: FR-S,GTI
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
