Old 06-12-2014, 01:24 PM   #85
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I would not agree with that statement.
When I say last I mean years of constant beating. And when I mean beating I mean driven by a kid who is no pro shifter either.
There is evidence yes of peoples perfectly fine tranny's that check in, but that's because either they don't rag on the car, or they have been driving a stick for a long time. (I've never driven a stick so the thought of going FI on a manual 86, I worry about the transmission since I'm not the best shifter in the world)
I guess for me it would be more of a piece of mind to know that a replacement tranny like the V160 or more practically the auto with SSP upgrades, is more than sufficient for a less than stellar shifter and power output.
Old 06-12-2014, 04:27 PM   #86
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by WingsofWar View Post
i made a thread of the changes the FA20DIT has vs FA20. Including lower compression pistons and watercooled EGR.
So... wheres the thread??
Old 06-12-2014, 04:48 PM   #87
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I can't find it
Old 06-13-2014, 01:56 AM   #88
Top-Secret
Drives: FRS monogram
sweet im glad to see people getting back into this as i was just going to start something like this on my own. and even better that Sportsguy83 is here because youre really the reason this even came into my head.
my buddy and me have been talking about forced air with the compression on the frs/brz with it being 12.5:1 that is already very high as it is. adding 10lbs of boost you ''should'' be around 21:1 and 20lbs of boost ''should'' be around 29.51:1
now those are some insainly high compression ratios. and to me it sounds like it shouldnt work. but clearly it is. and no one can seem to understand why or howlong.
i mean if sportsguy83's car is still running well on 20lbs, running e85 if i can remember correctly which would bring compression down a fair bit but not far enough to be a practical DD. thinking about this the last 2 days has made my brain hurt.
Top-Secret is offline   Reply With Quote
Old 06-13-2014, 11:07 AM   #89
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My advice is to think about turbo diesel engines.
Old 06-13-2014, 11:48 AM   #90
andrew20195
Drives: 2013 Subaru BRZ
While your concern about cylinder pressure is on the right track, the static compression ratio of 12.5:1 does not tell you how much pre-combustion cylinder pressure you actually end up with. On any engine, due to valve timing, the dynamic compression ratio is lower. Sometimes much lower. On top of that you have the pressure wave effect of intake and exhaust plumbing which affects how much air ends up in the cylinder.
The issue of high pre-combustion pressures is that the air/fuel mixture can heat up to the point of spontaneous ignition (detonation). One of the benefits of direct injection engines is that they can run much higher cylinder pressures due to the cooling effect of injecting fuel during the compression stroke, especially using fuels like e85.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
CxG (10-28-2015)
Old 06-18-2014, 03:36 PM   #91
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
sorry couldn't get back to you until now been busy with the quarter and balancing 2 kids, this is my last week of the quarter thank god!
http://www.ft86club.com/forums/showthread.php?t=8025
WingsofWar is offline   Reply With Quote
The Following 2 Users Say Thank You to WingsofWar For This Useful Post:
FearBoy (06-19-2014), Sportsguy83 (06-18-2014)
Old 06-18-2014, 03:40 PM   #92
Sportsguy83
Drives: Limited BRZ
Thanks!!
Old 06-19-2014, 04:08 PM   #93
FearBoy
Drives: 2013 BRZ Limited
I didn't see anything about lower compression pistons in that thread. As a matter of fact is was changes to the FA20, not differences from the FA20DIT. Where's the "real" thread?
FearBoy is offline   Reply With Quote
Old 06-19-2014, 05:24 PM   #94
andrew20195
Everything in that thread pertains to the FA20DIT, not the FA20 in our cars as WoW may have thought when he originally posted it two years ago.
Nonetheless, the content is valid with respect to the DIT engine. And yes, the compression is lower than on our cars.
FearBoy (06-23-2014)
Old 06-23-2014, 04:51 PM   #95
FearBoy
Thanks for clarifying.
I was hoping read that the crank and rods of both engines were the same, but just with different pistons to achieve the desired CR.
Old 06-25-2014, 08:35 AM   #96
andrew20195
I can guarantee the rods are different. I had our parts department look them up.
Old 07-14-2015, 02:29 PM   #97
nijat12
2015 FR-S RS 1.0 - Miami
nijat12's Avatar
Drives: 2015 Scion FR-S R.S 1.0
Just to bring this thread back to life since so much time has passed and hopefully people are more knowledgable about our cars. How reliable is it to FI these cars?
Is there a scenario that it can be done with the most little amount of headache down the line while Dailying it.
Basically to put down money and get a faster version of our cars as if Toyota/Subaru made them
nijat12 is offline   Reply With Quote
Old 07-14-2015, 03:15 PM   #98
raven1231
No.
There is always more risk involved as they engines were not built to hold up to FI. Yes, there's a chance your car will be fine, but for how long?
It seems as though generally the lower the psi and hp/tq numbers are the better, as well as keeping the IAT's to a manageable number and getting a reputable tuner to tune your car.
Meng Motorsports Super Bright and Reliable LEDs Sale! Low Price! Mengsta Exterior Parts - Lighting 69 08-19-2013 03:52 PM
Reliable LED kit companies? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-27-2012 10:38 PM
mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal mines13 Other Vehicles & General Automotive Discussions 16 03-30-2012 03:30 PM
