| Subaru BRZ General Forum All discussions about the Subaru BRZ coupe |
#1 | |
NINJA MODERATOR #2
Drives: 87 FC3S TII
![]() FT86CLUB Homepage Featured Story Today, I was on the phone with a friend in Japan who is one that is head over heels about the GT86. While Subaru and Toyota information leeks have stopped...... for now... There has been some idle talk in the JP BRZ/86 community about the upcoming models. (Remember these are only predictions and rumors from the land of the rising sun)1 of which is the changes that are being made to the FA20...particularly FA201. +Some have been concerned about the mid range dip found on the BRZ torqeband, spawning many different theories with no real conclusive explanation. Intake acoustics have been found to have the greatest effect on this... Subaru's solution for next year is to adopt TGV into next years model lineup. Quote:
so basically we are getting OEM ITBs...lol +Water-cooled EGR with a collector..might also be adopted into the FA201. Although I don't really see how this is a benefit for greater emissions. +Talks of Denso being switched out next year in favor of Hitachi DI injection drivers ECU and Hitachi injectors with a dual spray pattern. While many of these things have already made its way into the current Legacy GT DIT Featuring a DI only FA20 Twin Scroll Turbo, I don't hear anything about the actual turbo itself being implemented into the BRZ platform. So we are still less likely to see this under our hoods from the factory. So what can we expect? More power? No I don't believe so. but i do expect plenty of improvements in our current power band output, and economy. It is unclear if the Toyota/Scion twin will also be having next year's changes, but given their contract and also being built at the same plant...the odds are very high that Toyota/Scion will also have these changes as well. Thoughts, Comments, and Concerns are welcome. Bitching and moaning will not tolerated in this particular thread. -Josh
| The Following 50 Users Say Thank You to WingsofWar For This Useful Post: | 00NissanNinja (06-06-2012), 2013GTRNate (01-01-2013), ajay (06-08-2012), Apex Chase (05-09-2013), Asterisked Accolade (06-19-2012), baldolera (06-19-2012), Bristecom (06-07-2012), carbonBLUE (06-07-2012), Chad (08-24-2012), Chenslee (06-08-2012), civicdrivr (06-13-2012), cmspooner (08-21-2012), cyde01 (06-20-2012), Deepseadiver (09-09-2012), Dr.Science (06-07-2012), engee (06-08-2012), ESBjiujitsu (06-08-2012), Fly Guy (06-07-2012), gdi2290 (09-03-2012), Giccin (06-07-2012), Guff (06-07-2012), Hix (08-21-2012), hyper4mance (08-21-2012), Jayde (06-06-2012), jinrawke (06-08-2012), jmaryt (09-09-2012), Mango22 (12-29-2012), MannyO (06-06-2012), mattles (06-06-2012), MoarGeesPlease (07-21-2012), NorCalRider (06-08-2012), pyro530 (06-07-2012), RaceR (06-06-2012), ROJ (06-08-2012), RRnold (06-07-2012), Scooby South (09-21-2012), SioXie101 (06-10-2012), Smudgeous (06-07-2012), Snoopyalien24 (06-06-2012), stalon320 (07-14-2012), Streetice (06-15-2012), TheRipler (06-06-2012), TRD_07 (06-09-2012), tripjammer (09-22-2012), Turbowned (06-07-2012), wcbjr (06-08-2012), WRXGuy1 (06-06-2012), YukiHachiRoku (06-07-2012), Zaku (06-07-2012), ZmZMWagon (06-06-2012) |
Drives: MS3
So this kind of goes with the early rumors about there being improvements every year to this platform engine wise.....
ZC6A2B82KC7J
Drives: 2002 WRX
Interesting... TGVs are usually the first thing people remove on a WRX
| The Following 2 Users Say Thank You to Spaceywilly For This Useful Post: | Spartan65 (08-21-2012), Thongpocket (02-22-2013) |
Habitual Line Crosser.
Drives: ^ Two of my favorite things.
Typed the words right off my finger tips...
But, but, but... It's only 200 hp?!
Re-member
Drives: Toyota Sorara
I have mixed feelings about the TVG. On the one hand better power/torque curves are always welcome but on the other it adds complexity and is one more variable that car enthusiasts have to deal with, which is a turn off. We want a greater ability to modify the car ourselves and this ability is slowly eroding. If the TVG system makes it harder to tune or realize Hp gains it may end up being a negative for the car and the brand. This car is already loved not only because it handles well but because its a simple design that appeals to car enthusiasts in a similar way as the Honda B or K engine. Perhaps a more elegant and simple solution could be found that does not include valves in the intake plenum. If the TVG system doesn't get in the way of aftermarket support or possibilities thereof then I am all for it. Either way, I watch with excitement to see how this engine will evolve.
Nothing decays like progress, and nothing preserves like neglect.
| The Following User Says Thank You to ahausheer For This Useful Post: | Streetice (06-15-2012) |
#6 | |
NINJA MODERATOR #2
Drives: 87 FC3S TII
TVG is mainly used in the past as a primary purpose to restrict air flow, during idle resulting in reduced emissions. But with DI in place and a weak stratified charge injection at idle, the idle emissions and fuel consumption has already made signficant improvements. Making TVG redundant... TVG was really counter-productive in WRX with already horrible manifold AITs from the factory being turbo and experiencing noticeable heat soak. Does the FA20 also suffer from the same AITs with its phleonic resin compound intake manifold and not experiencing hot intake charges? Why couldnt subaru use variable intake lengths if they were really targeting smoother TQ charcteristics via intake accoustic tuning? Rather than go TVG.. FA20DIT....wheres the dip? look at that graph...is that the same FA20 with just a turbo? This is really impressive on a non-STI turbo subaru engine and with a incredibly low emissions table compared to the EJ. ![]() With DI in place, we really ultimately require less air to make power per stroke, vs the ratio of air+port fuel where we pretty much guess based on tailpipe AFRs.
| The Following User Says Thank You to WingsofWar For This Useful Post: | Streetice (06-15-2012) |
Drives: 2000 MR2 Spyder
I dunno how much TGVs hurt flow at high rpm, but if they work well this is a better way to do it than D4-S with a compromised port for low speed stability. arghx7 said that the ports are likely a compromise between tumble and flow, so I think gains in flow aren't really going to happen on the current engine. WingsofWar, TVG is absolutely not redundant! Stratified charge can only be used in a very narrow set of circumstances, TVG is what's going to get you great low end torque without killing high end power completely.
Cooled EGR is a good thing for fuel economy at part load, although very high AFR lean burn is probably better :P Good to see them making improvements. |
Kuruma Otaku
Drives: BD Legacy and Mk3 Supra Turbo
Also TGV (modern TVIS) and variable length intake systems are not mutually exclusive. However I would prefer a better design for increasing low rpm intake velocity than the TGV setup.
As for the Hitachi injectors, unless it's going only DI, due to Toyota, Denso and Yamaha patents on the D4-S it won't happen. (Assuming no change in business dealings.) Finally with boost fidling they can create an artificially flat torque curve (ie add boost to fill any dips).
Because titanium. |
Re-member
Also, variable intake lengths as used in Toyota V6's and many Lexus engines develop amazing torque curves, although I am still learning about the pros and cons of Toyota's TVIS and Subaru's TVG's so I really don't know what I am talking about.
#10 | |
Re-member
Why do people remove the TVG's?
#11 |
Drives: 2009 135i
fuck, TGVs suck... everything else seems promising
#12 | |
ZC6A2B82KC7J
Drives: 2002 WRX
It is only there for cold start emissions. After the engine warms up they just impede airflow and heat up the air. Removing it increases power through the entire power band.
http://www.grimmspeed.com/catalog/pr...products_id=35 Quote:
#13 | |
I guess we'll just have to see, as usual. |
#14 | |
Kuruma Otaku
![]() Did they think the smaller 2.5l V6 needed more help than the 1000cc larger motor?
Because titanium. |
#15 |
Mr. Sarcasm
Drives: 1996 Coro's Rolla
So, this is our "mule in camo" till next year?
I love it. Thanks WoW. Deff will be waiting this out to see what happens
#16 | |
On the 3.5L motor, they have port injectors to "limp" around at low rpm, that's how I think of it. Except the only thing is the port + direct happens to give a slight improvement over either alone, so you can't really call it limping. |
#17 | |
Kuruma Otaku
20% VE penalty at 6400 rpm (probably even worse as rpm increases) for 4% more torque at 2800 rpm? Fuck. That. Shit. No way SCV/TGVs are going on this motor. (If the .pdf isn't in arghx7's D4-S stickied thread, let me know and I'll attach it. Title is 'Toyota 2GR-FSE GDI PFI engine paper.pdf' Edit: it's in his sticky. IS350 section.
Because titanium. Last edited by Dimman; 06-07-2012 at 01:13 AM. Reason: edit |
| The Following 2 Users Say Thank You to Dimman For This Useful Post: | Calum (06-07-2012), vividracing (06-08-2012) |
#18 |
It's not about the peak torque, it's that combustion stability is affected across the board so you'll probably have rough idle and misfires or significant torque fluctuations, all that shit, if I understand correctly.
arghx7 indicated that the ports on D4-S engines are likely a compromise between tumble and flow, because you really do need the tumble at low speed for the direct injection to work. The port injectors give you more room in terms of how much tumble you need. Basically, you're kinda forced to have a flow compromise of some sort, and I have this gut feeling that TGVs are the better option. Now of course BMW and Porsche and whatever don't seem to have issues with this, but arghx7 makes it sound like their stuff is much fancier and more capable, so I'll believe that for now even though I don't quite understand how it works. For Porsche I think reduced valve lift increases tumble flow or something with the right design, so they're okay. Not sure how BMW deals with high/low rpm compromise on their S-- engines with only double VANOS, but I'd guess their injector placement and firing have something to do with it. EDIT: wait, BMW S-- engines don't have direct injection? Okay that clears things up. |
#19 | |
Kuruma Otaku
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | Calum (06-07-2012) |
#20 |
I'm different, yeah I'm..
Drives: Attitude
TGVs are not OEM ITBs...
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | bimmerboy (06-08-2012), civicdrivr (06-13-2012) |
#21 | |
The paper didn't say D4-S was to break the compromise, rather it described the flow compromise that a DI engine sees, the efficiency disadvantage that port injection has, and then they went on and talked about their new engine, without actually saying what they did to the ports. |
#22 | |||
Kuruma Otaku
The purpose of the Yamaha developed double fan spray pattern is Quote:
Because titanium. |
| Advantage FRS or Disadvantage BRZ (major concern?) | Skippy John | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-14-2012 05:37 PM |
| 2011 Subaru STI Minor Paint correction | OTD | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 18 | 06-05-2012 02:36 PM |
| Advantage FRS or Disadvantage BRZ (major concern?) | Skippy John | FR-S / BRZ vs.... | 3 | 05-28-2012 04:04 PM |
| BMW Z4M Minor paint correction/ Photo shoot | OTD | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 05-26-2012 11:15 PM |
| 2014 gtr | Shevon | Other Vehicles & General Automotive Discussions | 3 | 04-13-2010 11:48 PM |
