08-14-2019, 07:32 PM | #351 | |
Second off, what do you do with all your free time - not being on forums? Next off, what code is giving the CEL? You can read it yourself or ask the local auto parts shop to read it for you. Without knowing the trouble code, we have no way to determine it's seriousness. As far as your car, if it's still running - that's a good sign. - humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | mswbrz (08-14-2019) |
08-14-2019, 08:29 PM | #352 |
Drives: 2013 Hot Lava FRS
08-15-2019, 07:48 AM | #353 | |
I find that the forums tend to be a bit like webMD for me— always causing me to think something is wrong when it isn’t. Plus I spend WAY more time than I should on another forum already— avsforum. I’m on the road right now on the way to the dealership. I have the codes written down from the previous work. Will update with whatever they find today. Yes, I’m glad the car is still running but reading reports of owners who experienced engine failure (some while on the freeway!) has me more than a little concerned that my future is grim. My idle has been remarkably rough and that seemed consistent with the air / fuel sensor being bad. Now, after reading here and other places, I’m afraid the issue may be more serious. |
The Following User Says Thank You to NannerpussPRO For This Useful Post: | humfrz (08-15-2019) |
08-15-2019, 10:46 AM | #354 | |
humfrz |
08-15-2019, 11:17 AM | #355 |
Vehicle Milage: 53,xxx miles.
Vehicle Make: 2013 BRZ Milage after Recall: less than 1 mile, yes 1 mile. Symptoms: Ticking, Knocking. Engine blew again on technician after repairing the first failure. Length of time car was at dealership: 6 months. Here I am two blown engines later and six months of not having my car. At this point I don’t want the car back, but they won’t repurchase the vehicle, now that it is repaired. Initially they offered me $3,500 and a 3 year/36,00 miles warranty. After almost finalizing it, they told me I would actually only get a one year limited warranty. I don’t drive it often so I am worried if it gives out for a third time I won’t be covered. |
The Following User Says Thank You to Tgutz21 For This Useful Post: | mswbrz (08-15-2019) |
08-15-2019, 12:04 PM | #356 |
Dismember
Drives: 2013 Red Scion FR-S
Wow, what dealer is that?
08-15-2019, 12:33 PM | #357 | |
Drives: 2013 brz limited / galaxy blue
God damn bro , that's some shit right there I'm truly sorry and hope you had at least a back up car which sounds like you do since you don't drive yours often like myself . What dealer is this ? They going to charge you again for the third engine ? Same tech did the fuck up 2x? Sent from my iPhone using Tapatalk |
08-15-2019, 01:04 PM | #358 | |
They are keeping the car. Code still shows the fuel air issue but the sensor is in spec. They want to check valve clearance. And away we go... |
08-15-2019, 06:17 PM | #359 | |
What is the code? humfrz |
08-16-2019, 04:36 AM | #360 |
Drives: MY14 86 GTS Manual Velocity Orange
I know nothing about these engines but with all these failures surely a better solution would be for Toyota/Subaru to come up with a traditional gasket solution to seal these up instead of using liquid sealant? Probably not even possible due to engine design?
08-16-2019, 05:22 AM | #361 | |
Not going to happen. There are spots where 3 parts come together and with varying tolerances due to manufacturing coupled with assembly variances, the gaps are never the same. There would be no way to make a rubber gasket that would accommodate all this variance. There is a reason they all eventually leak at the bottom right of the timing cover (the spot where there are several intersections). If a standard gasket was used it would leak right from the factory. |
08-16-2019, 10:49 AM | #362 | |
Benz Tech
Drives: 2017 BRZ Premium
They put out a recall with limited training and a terrible punch time. Experienced guys rushed, or dumped it to an hourly tech. Mistakes are made and sadly there are consequences. I've worked in Mercedes dealerships in Virginia, Montana and Oregon for 14 years. We've been using liquid sealant since at least the '80s? I have never, not once, seen an engine damaged by scraped off sealant. It's a matter of experience and a whole lot of give-a-shit. I've been in Toyota shops, it isn't necessarily the top 1% of UTI they hire, I'll leave it at that. |
The Following 2 Users Say Thank You to maslin For This Useful Post: | Tcoat (08-16-2019), Ultramaroon (01-15-2020) |
08-16-2019, 06:35 PM | #364 | |
humfrz |
Tags |
fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
Similar Threads | ||||
2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
