Old 03-24-2022, 11:30 AM   #99
ka-t_240
Originally Posted by Breezio View Post
Interesting, I just looked at Discount Tire, Discount Tire Direct, and Tire Rack for A052s, and they were all the same price, within one dollar per tire at $258
Discount Tire Direct often runs sales, and promotions when you use their credit card. They also had a rebate available on yokohama last week(end) and Tire Rack did not.
ka-t_240 is offline   Reply With Quote
Old 03-25-2022, 02:40 PM   #100
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What are you guys liking for ride height? Didn't see it discussed in this thread, so thought I'd bring it up. I know it's not that important for STX, but I'm always curious what other people are doing now.
smg1138 is offline   Reply With Quote
Old 03-27-2022, 02:56 PM   #101
Autoxer62
More than most here, as I recall I'm at 350mm hub to fender. But, I have very little evidence on if that's good or bad.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
smg1138 (03-28-2022)
Old 03-27-2022, 04:11 PM   #102
strat61caster
strat61caster's Avatar
I’m at the low end of 949s suggested ride heights last I checked, 7mm of rake, maybe less, haven’t checked in a few months.
https://www.ft86club.com/forums/show...&postcount=215
133mm F
140mm R
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
smg1138 (03-28-2022), timurrrr (03-28-2022)
Old 03-28-2022, 08:39 AM   #103
steverife
Drives: 2016 Scion FRS
Don't really know. Everyone seems to measure a different way. Ground to jack tabs. Center of hub to fender. Ground to fender. Inches. Millimeters. Tabs are kind of beat up and fenders get pushed/pulled when the liners get ripped out. So none of it is exact.
When I brought it out in 2020, it was a good 1" to 1.25" lower than Ray's (now Eric's) car. I raised it either .5" or .75" last year and it is better. I might raise it some more, just because the exhaust frequently scrapes.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
Old 03-28-2022, 02:06 PM   #104
smg1138
smg1138's Avatar
That's a pretty mild drop. Mine is currently 13" (330mm) measured the same way. This is the lowest I ever go though because I don't want to run into bump steer and scraping issues. It equals about a 1 finger wheel gap which I think looks the best aesthetically too. I was just curious because it seems like ride heights vary drastically for STX drivers. I guess at the end of the day, it doesn't matter very much, unless you go too low and screw up the suspension geometry.
Old 03-28-2022, 02:15 PM   #105
strat61caster
Suspension geometry doesn't seem to really factor in as much as travel and bump stop usage does. You run out of travel on most setups I've played with and researched, well before you get into wonky geometry effects. Car is decently well designed except for rear travel. Front roll center can get too low, but there's nothing wrong with it, it's just easy to improve, probably why a stiff bar works well too.
ineedyourdiddly
Pat (03-28-2022), smg1138 (03-28-2022)
Old 03-28-2022, 03:07 PM   #106
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
13" front and 13.25" rear (hub to fender)
The Following User Says Thank You to DocWalt For This Useful Post:
Old 03-28-2022, 03:40 PM   #107
steverife
More important question...
What's the deal with the autocross at NSS in May? On the roval? Or the parking lot outside? Will they use the runway and the transition into the parking lot like they did before they lost that site like 10 years ago?
smg1138 (03-29-2022)
Old 03-28-2022, 08:39 PM   #108
Autoxer62
Sorry for the ignorant question, but NSS is where/who? Link to event?
Old 03-28-2022, 10:43 PM   #109
Eric1855
Drives: LP DSP / CSP '13 BRZ
Nashville Superspeedway https://www.trscca.org/
Eric1855 is offline   Reply With Quote
The Following 2 Users Say Thank You to Eric1855 For This Useful Post:
Autoxer62 (03-29-2022), smg1138 (03-29-2022)
Old 03-29-2022, 07:26 AM   #110
steverife
As mentioned, Nashville Super Speedway.
Local event, nothing particularly special, unless they are autocrossing on the roval. It is just exciting to me because I probably ran there 5 to 10 times a year when I started autocross and ETR only had postage stamp lots. And then they lost the site.
Here's an old vid of mine that I found yesterday showing the lot. The transition to and from the runway was pretty unique.
Old 03-29-2022, 08:43 AM   #111
Autoxer62
That's a site that's worth driving on, I can see why you'd be excited to go back!
Old 03-30-2022, 04:34 PM   #112
ConnorJ
ConnorJ's Avatar
Drives: 2015 Series.Blue Subaru BRZ
From what I remember talking to some of the TRSCCA guys recently, it sounded like they had a joint rental with a drift club to cut costs. The drift club is going to use the track and autocross will be in the infield. I could be misremembering though. I'm tempted to head up there myself.
Connor Johnson
2015 Subaru BRZ Series.Blue
Tennessee Valley Region - STX #15
ConnorJ is offline   Reply With Quote
The Following 2 Users Say Thank You to ConnorJ For This Useful Post:
smg1138 (04-03-2022), steverife (03-30-2022)
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 05:13 AM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 01:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 110 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
