05-01-2015, 11:46 AM | #43 | |
The Following 3 Users Say Thank You to raven1231 For This Useful Post: |
05-01-2015, 12:42 PM | #44 |
The heat soak problem can be partially mitigated by changing the fan settings in the tune. For DD use the biggest problem is heat soak while idling. The fan settings can be changed to blow more at low speeds and while stopped, which could help a lot to prevent melted fans and wires. An oil cooler is definitely recommended though. I would also recommend running the A/C if stuck in stop and go traffic. The A/C fan can help cool the under-hood temperatures.
05-01-2015, 12:44 PM | #45 | |
The Following 3 Users Say Thank You to protpibe For This Useful Post: |
05-01-2015, 01:04 PM | #46 |
Drives: Neptune GR86
Nothing
05-01-2015, 01:49 PM | #48 |
And running the AC will make the heat problem worse. The second fan will come on without the AC if there's enough heat to need it.
05-02-2015, 02:11 PM | #49 |
Looking forward to some real world results.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | raven1231 (05-02-2015) |
05-02-2015, 06:07 PM | #50 |
Drives: FR-S 10 #103 AT
Why not hook up a thermocouple and a relay to kick them on based on underhood temps when needed.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
05-02-2015, 06:25 PM | #51 |
The stock ECU should already be doing that.
05-02-2015, 08:04 PM | #52 |
Turning is for Nerds
Drives: 35 characters is not enough
No, fans are switched on by coolant temps rather than engine bay temps. I had to modify the kick on point quite a bit to stop things from melting.
05-02-2015, 08:10 PM | #53 | |
What did you melt and on what turbo kit???
05-02-2015, 08:28 PM | #54 |
Fans showed some signs of beginning to go and the primary airbox resonator, this was on just a header.
05-02-2015, 08:45 PM | #55 |
Drives: 2017 Camaro 1SS
Why don't the fans just run all the time? Is there any time they shouldn't be running?
Similar Threads | ||||
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience | King Tut | Forced Induction | 196 | 09-04-2016 09:47 AM |
Cosworth Stage 2.0 In-Stock! WORKS Motorsports | WORKS | Forced Induction | 37 | 07-28-2015 08:18 PM |
Hello from WORKS Motorsports! **10% discount for FT86club members!** | WORKS | Northern California | 35 | 05-22-2014 01:20 PM |
Hello from WORKS Motorsports! **10% discount for FT86club Members!** | WORKS | Announcements, Contests, Giveaways | 1 | 04-16-2014 10:04 PM |
Stainless Works, experience? | Nourdmrolnmt1 | Engine, Exhaust, Transmission | 7 | 05-18-2013 04:07 PM |
