Forced Induction Turbo, Supercharger, Methanol, Nitrous |
07-15-2015, 11:26 PM | #15 |
Drives: dmg brz 2012
I'm gonna go with what AVOturboworld said.
I had a faulty 3 Bar MAP sensor, and it would just keep trying to crank and not turn over. Plug the factory one back in and see how you go. gav |
07-15-2015, 11:30 PM | #16 |
Drives: FT86
if you have changed MAP sensor or injectors its unlikely it will start or run on stock tune.
and it can actually be bad for engine as it may run extremely rich with unscalled replacement injectors. |
The Following User Says Thank You to steve99 For This Useful Post: | RedFR-s (07-16-2015) |
07-16-2015, 12:36 AM | #17 |
Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
I swaped my stock map for 3 bar when I bought the kit. So that's the problem then?
Running stock injectors, only upgraded fuel pump. i can confirm it was priming and pressurizing the line.
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
07-16-2015, 12:37 AM | #18 |
I don't have any files to tune, was running open flash but am getting Ecutek from my tuner tomorrow so I'm stuck on stock tune.
Andy
07-16-2015, 12:39 AM | #19 |
i was working on testing the system to make sure it would run. i'm getting it towed to my tuner tomorrow.
Andy
07-16-2015, 12:41 AM | #20 |
Sasha form On Point is doing it for me.
Andy
The Following User Says Thank You to RedFR-s For This Useful Post: | D_Thissen (07-16-2015) |
07-16-2015, 12:47 AM | #21 |
Drives: 10 series FRS
swap the map sensor and try again.
07-16-2015, 12:51 AM | #22 |
Unfortunately I don't have another one. I got the kit used and I saw it all running on his car about a week before I bought it, so I'm assuming it still works ok.
Andy
07-16-2015, 12:56 AM | #23 |
Sorry, I meant swap your map with your stock one.
When you were running the Open Flash, it was on the stock Map sensor right? |
07-16-2015, 01:16 AM | #24 |
I swapped my stock MAP for the 3 Bar one when I got the turbo kit. So I can't even try the stock one.
Andy
07-16-2015, 01:22 AM | #25 |
ahhh my mistake.
Hope you get it sorted buddy. |
07-16-2015, 09:48 AM | #26 |
I Love custom Turbo kits
Drives: Limited BRZ
Your car will not start unless the tune is tweaked for a 3 BAR MAP sensor. It's a simple table with two values the tuner can quickly change, but without that little change, it just won't start.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
07-16-2015, 09:51 AM | #27 |
Drives: GBS BRZ
I'm thinking fuel pump. What pump are you using? When I installed my full blown 270 (longer than stock) I tried to just shove everything back together and it would prime and would build some pressure but not enough. After I zip tied the filter on and added a few o rings on the neck it worked fine.
The Following 2 Users Say Thank You to bee_are_zee For This Useful Post: | brosifSmith (04-25-2019), Sportsguy83 (07-16-2015) |
07-16-2015, 10:17 AM | #28 |
NASA SpecE30 Racer
This. I ran into the same exact problem when I swapped my MAP sensor out. The voltages for the MAP sensor have to be changed in the tune before the car will start. Find a local buddy and put his OEM MAP sensor on to verify the car will start.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (07-16-2015) |
Similar Threads | ||||
AVO Turbo Kit Install | Dammod | AFRICA | 110 | 09-10-2016 12:54 PM |
New Turbo Install = Car Fumes?? | xuimod | Forced Induction | 49 | 04-28-2015 03:21 PM |
BorgWarner EFR / JDL turbo install!!! | Infamous Performance | Forced Induction | 89 | 01-21-2015 11:38 PM |
Fa20club turbo install issues | Mikegraves777 | Forced Induction | 8 | 07-25-2013 12:56 AM |
Fire extinguisher install | ICantAffordAnLFA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 10-18-2012 06:37 PM |
