Old 06-04-2021, 02:04 PM   #29
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by yEEt42069 View Post
Hey sorry for the super late response. I did get the extended wire harness and it was very easy, plug and play. You do have to play around a little with fitting the airbag back on because there is a little more wire sitting around.
Thanks for getting back to me. I actually installed it this past weekend with zero issues. It was a lot easier than I thought. I'm always hesitant with the clock spring and the airbag but I made sure the clock spring was held down as I pulled the steering wheel so it didn't move. Took me no more than 20 mins taking my time and with the extender there was tons of wire.
All that said and done, it's a totally different experience driving the car. I can sit back comfortably, and the steering wheel is positioned perfectly, not to mention it no longer hits my knees so I have full rotation and can apply proper torque while driving. I kind of wish I got it ages ago.
Any one on the fence about getting this should buy it immediately. If you've never quite been comfortable and felt the steering wheel was too far or you were leaning forward to wrestle the steering wheel this is the answer!
Great job @949 Racing!
RayRay88 is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
949 Racing (06-11-2021), Thefalls (06-07-2021)
Old 04-24-2022, 06:53 PM   #30
George Rosebush
Drives: 2015 Scion FRS
Originally Posted by Capt Spaulding View Post
2. The added distance puts a serious stretch in the horn wire. I battled mine for quite a while and ultimately admitted defeat and fabbed a 2" jumper wire. [949 guys - including a short jumper would help those of use with big clumsy mitts]
I had the same issue, it would unplug when trying to install the airbag, how do you fab up this extension? What parts needed?
George Rosebush is offline   Reply With Quote
949 Racing 50mm Steering Spacer 86 - GR86 949 Racing Tracking / Autocross / HPDE / Drifting 195 04-18-2022 11:45 AM
Spacer install EzyBrzy Northern California 1 03-05-2016 03:52 PM
Vibrations After Spacer Install Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2015 12:20 PM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
