Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-02-2021, 12:24 PM | #43 | |
I've seen steady state around 199-201 which a couple peaks and dips along the way. Oil temp is sub 230F even on hot and humid days
Kyle H. - #89 STX
08-02-2021, 02:04 PM | #44 | |
In the case of my car, while I'm on a stock radiator, I have every other supporting modification known to man, including a fully ducted cooling stack and a divorced oil cooler. I do eventually overheat; my threshold is between 107F and 115F. Under 107F, I don't overheat at all, over 115F, I overheat for sure. I don't know exactly what the threshold is, because I haven't run any track days with a temp between 107F and 115F to find out. At 107F, I don't overheat with the heater off; at 115F I overheat, even with the heater going full blast. The above data is at my high boost setting (~360whp). |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
08-04-2021, 09:48 AM | #45 | |
Drives: 2013 frs base
Sounds like it's stuck
Sounds like Schrodinger's thermostat: It's neither closed nor open. |
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | rice_classic (08-31-2021), Ultramaroon (08-05-2021) |
08-21-2021, 11:48 AM | #46 |
Drives: Crapcan
Thermostat change yielded no improvement. 70-75f ambient. Still hitting 235 in a 25 min session. Water pump is next. I am also going to test and verify my sensors with a thermocouple.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (08-21-2021) |
08-21-2021, 02:25 PM | #47 |
Drives: Crapcan
Bad temp sensor
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
08-21-2021, 03:16 PM | #48 |
義理チョコ
Had the same with my Eclipse! Ran like shit until I figured it out. Well done!
08-21-2021, 10:05 PM | #49 |
What sensor?
08-21-2021, 10:07 PM | #50 |
Drives: Crapcan
Aftermarket coolant gauge.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
08-31-2021, 06:25 PM | #51 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Glad you got it figured out!
Going off your thread title, I want to chime in on my setup. I'm curious how my Edelbrock performs on the track with heat management. I have the Jackson Racing Rad/OC combo unit along with hood vents. I do feel like the system can get heat soaked, and i'm curious what else I can do to mitigate that. Again, the heat soaking is fairly anecdotal as I am not currently datalogging while it is happening. (only had the new BRZ for 4 weeks) That said, I have some track days/hillclimbs coming up in September so I want to get ahead of any heat issues. Picked up an OBDLink MX+ Bluetooth unit that will help monitor temps.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
08-31-2021, 07:05 PM | #52 | |
You can show coolant, oil, and intake temps simultaneously, as well as more track data if you want. You can also do the same with Ecutek Connect, and any old phone you have, and a phone mount. More powerful fans and a good fan shroud can help. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Aztec (08-31-2021) |
08-31-2021, 07:39 PM | #53 | |
Drives: Crapcan
09-01-2021, 12:49 AM | #54 | |
I also just picked up a dji action cam for in-car POV
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread Last edited by Aztec; 09-01-2021 at 04:44 PM. |
09-01-2021, 01:44 PM | #55 | |
Drives: Crapcan
Maybe @timurrrr can comment it, but I thought you could show OBD data on racechrono. It will log the data, I haven't messed with it a bunch yet as far is getting the displays setup.
Similar Threads | ||||
Engine Management | Q2 | Forced Induction | 9 | 12-04-2017 05:37 PM |
heat management, CF hood alternative | Reaper | Forced Induction | 70 | 07-05-2017 01:22 AM |
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) | glamcem | Forced Induction | 56 | 08-25-2014 06:07 PM |
Top half car covers for cabin heat management on track | dp1 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-26-2014 11:08 AM |
Avo turbo heat management on track | ICantAffordAnLFA | Forced Induction | 18 | 09-09-2013 11:00 AM |
