05-27-2023, 02:31 PM | #1149 |
Drives: '13 BRZ TLM Spec
Duh, I know it will, eventually. Just saying that the short amount of time driven in the video shouldn't have caused it to so soon.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
05-27-2023, 02:33 PM | #1150 | |
Drives: GR86
You get a nail in a tire with road hazard coverage. You keep driving on it while it's flat and you completely shred the tire, damage the wheel, and none of your warranties cover that because you ignored signs of impending damage. If you'd stopped when the tire went flat, everything would have been covered. ALL warranties require the owner to take reasonable action to correct/avoid problems. Failing to do that voids the warranty. If damage is done by something covered under warranty, but you ignore it and keep driving the damage PAST that point is not covered because you chose to cause it. Again - I'm not saying that's what happened here, I'm simply saying that based on the VERY limited evidence we have there's at least the possibility that part of the reason the claim was denied may have been that there appears to be wanton disregard for the engine past the point where the warning lights came on. |
The Following 2 Users Say Thank You to Spektyr For This Useful Post: | soundman98 (05-27-2023), vindiesel (05-27-2023) |
05-27-2023, 06:58 PM | #1151 | |||
ProCrastinationConsultant
this is a straight copy/paste from the 2023 manual, but i believe the gen-1 manual read the same for the america's. in other countries manuals, 5w-30 was in the same section and allowed based on availability. that was where a lot of people get the idea that it's allowed. but the american manual doesn't state it, which means the american warranty can't apply. Quote:
he said he filled the car with 5w-30, which is where/how they can outright deny warranty coverage, even if he fights them on the track usage. at this point, the only saving grace he's got is public outcry. just for fun, i looked up my 2014 manual, it doesn't even list 5w-30 as an option: Quote:
The Following User Says Thank You to soundman98 For This Useful Post: | Clipdat (05-28-2023) |
05-27-2023, 08:56 PM | #1152 | |
05-28-2023, 09:48 AM | #1153 |
1st86 Driver!
That's true with just about any type of warranty/insurance. A pot of grease on you stove catches fire, you go outside and watch your house burn down before calling the fire department, very unlikely you insurance company is going to cover it when they find out.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
05-28-2023, 10:32 AM | #1154 | |
Drives: '22 BRZ
I went from initial knock to windowed block in <60 seconds... a friend with an FA20 went from tossed rocker to absolutely obliterated engine due to oil pressure loss in <10 seconds. YMMV
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
05-29-2023, 12:26 PM | #1155 |
Drives: Crapcan
Mine was 10-20 seconds from the time I noticed power loss, looked at my gauge and saw no oil pressure, to bang.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DocWalt (05-29-2023) |
05-29-2023, 05:47 PM | #1156 |
Anti stance.
It’s impossible to draw such a conclusion. What was the spec on the bearing clearance on the car in the video? Was it on the tight side of tolerance or the loose side?
05-30-2023, 02:25 AM | #1157 |
義理チョコ
Some of you may call bullshit but I swear I hear the telltale chugging sound right from the beginning. Listen to whenever he gooses it at lower revs. Rod bearing scuffing under load.
05-30-2023, 10:17 AM | #1158 | |
Drives: 2018 Subaru BRZ Limited with PP
Just to be clear, I'm not here to say that this guy deserves a covered engine. I am only disputing your original statement of warranty coverage over whether he continued to drive it or not after damage had already occurred. That just can't be a reason for warranty denial. Say I'm driving home from work on a highway and my oil pressure light comes on. I need a bit of time to merge over a few lanes to pull over and my engine blows in that process. Does this mean I ignored the warning and therefore my engine should not be covered under warranty (in a perfect scenario of a fully stock vehicle with up to date maintenance of course)? No, it absolutely should, because whatever fault was there, was there. The fact that I drove it to a further fault does not give the original problem any justification. |
The Following 3 Users Say Thank You to Dzmitry For This Useful Post: |
05-30-2023, 10:34 AM | #1159 | |
Drives: 2018 BRZ
Problem is that everyone has a different definition of the "reasonable person", so it might very well require going to court over. |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Dzmitry (05-30-2023) |
05-31-2023, 08:46 PM | #1160 |
Drives: 2023 brz limited 6mt red
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
The Following 11 Users Say Thank You to vindiesel For This Useful Post: | bcj (06-01-2023), Clipdat (06-01-2023), Dadhawk (06-01-2023), Desertnate (06-01-2023), DocWalt (06-01-2023), Dzmitry (06-01-2023), gcmak (06-02-2023), Mr_Brian (06-07-2023), soundman98 (06-03-2023), strat61caster (06-01-2023), Tokay444 (05-31-2023) |
06-01-2023, 12:54 AM | #1161 | |
Proud of BOXER
Drives: Subaru Boxer
lol @ proud partners of Permatex.
06-01-2023, 10:54 AM | #1162 | |
Drives: '23 BRZ
Also, I don't think they would *necessarily* deny the warranty claim based on 5w30 synthetic. My advice: if you do run 5w30 during warranty period, don't tell anyone about it... |
The Following 6 Users Say Thank You to ZDan For This Useful Post: | Arthur-A (06-02-2023), DocWalt (06-01-2023), gcmak (06-02-2023), soundman98 (06-03-2023), strat61caster (06-01-2023), Tokay444 (06-01-2023) |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
