07-24-2012, 12:03 PM | #29 | |
Drives: 2016 STI DGM
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post: | michaelahess (07-24-2012) |
07-24-2012, 12:33 PM | #30 | |
1st86 Driver!
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | KRAZYK (07-24-2012), michaelahess (07-24-2012) |
07-24-2012, 02:37 PM | #31 |
Drives: Scion xA
Nope you're not the only one. The truck I use for work has that feature and all it does is annoy me cuz I'm not a lazy tool who flicks my signal for a second and thinks that's good enough. The only time I ever tap my turn signal is if I'm about to turn and realize I'm turning at the next one or whatever.
07-24-2012, 03:12 PM | #32 | |
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
08-06-2012, 09:37 PM | #33 |
Drives: '89 911, '06 GTI, '13 BRZ
OK, just received my tap turn relay module. Now were the heck is the flasher relay on a BRZ?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
08-06-2012, 11:42 PM | #34 |
Drives: 2013 BRZ, 2002 WRX
Fuse box? :shrug:
08-07-2012, 12:09 AM | #35 |
Drives: 2013 Scion FR-S Firestorm Red MT
Will be checking this out! I do like the additional features of the hazard lights too!
Was raining down hard today, was wishing I had the F1 style rear-fog going!
08-07-2012, 12:49 AM | #36 |
Drives: DGM BRZ Limited, 05 Baja Turbo
With your head under the steering wheel, the flasher sits just below the steering column, just to the left. It's an 8-pin Toyota-style flasher, and the wire harness faces the firewall.
I know this because I can no longer hear factory turn signals, so had to replace mine with a louder one... |
08-07-2012, 05:38 AM | #37 | |
2005 Honda XR650L
08-07-2012, 07:59 AM | #38 |
Guest
Posts: n/a
A DIY and review of this would be great once someone installs it
08-07-2012, 09:50 AM | #39 |
Yes, it doesn't sit very high up or too forward, so it's easy to unplug it...it's visible and accessible from underneath without removing the plastic panel under the steering wheel. And BTW, I just left the original flasher in place after unplugging it, and used some 3m interior adhesive trim tape to secure the new flasher to a nearby flat surface. Probably if you remove the lower plastic panel you can get easy access to the screw/bracket that holds the flasher in place, but I decided it was easier to just leave the old one where it was -- one less thing to track down if I decide to reverse my installation in the future.
08-07-2012, 11:37 AM | #40 | |
Self Entitled
Drives: 13' Red FR-S, 12' Toyota Tundra
Sounds pretty much plug and play right? Does this device also remotely control the windows or is this just for the tap turn feature? |
08-07-2012, 12:01 PM | #41 | |
2005 Honda XR650L
08-07-2012, 12:40 PM | #42 |
Installed. Awesome little module. Does different hazard modes, as well. Could get in trouble with that wig-wag pattern.
Similar Threads | ||||
Turn signal lights | Brzer | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-18-2012 01:36 PM |
Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 03:32 AM |
Turn Signal Repeaters | Ben_G | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2012 10:26 PM |
FINALLY My Turn! | Gaiakai | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-12-2012 12:52 AM |
