Old 07-24-2012, 12:03 PM   #29
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Originally Posted by KRAZYK View Post
Says you can program it for more than 3 flashes if you want..
The 3 flash thing is just a common tap-flash configuration equiped in some cars and trucks. I had it in my last truck and loved it.. obviously there are times for it - and other times 3 isnt enough so you have to do it manually.
I have an SUV that has it and have never found that 3 to be nearly enough so I still do it manually... Then again, I'm probably the only person on the road that actually uses my indicators religiously...
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
michaelahess (07-24-2012)
Old 07-24-2012, 12:33 PM   #30
Yeah I understand. I still find it usefull at times, but not all the time.. I guess this is good news for you anyway - you dont have the urge to spend $80 to add it on!
The one for sale above says you can adjust it up to 6. I did some unscientific polling on my commute this morning. 6 was more than adequate in any situation I saw.
KRAZYK (07-24-2012), michaelahess (07-24-2012)
Old 07-24-2012, 02:37 PM   #31
F-Bomb
Drives: Scion xA
Nope you're not the only one. The truck I use for work has that feature and all it does is annoy me cuz I'm not a lazy tool who flicks my signal for a second and thinks that's good enough. The only time I ever tap my turn signal is if I'm about to turn and realize I'm turning at the next one or whatever.
F-Bomb is offline   Reply With Quote
Old 07-24-2012, 03:12 PM   #32
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
This thing actually allows you to cancel in these situations, too, by intuitively just tapping again. The other OEMs stock signals don't, as far as I'm aware.
thorlius is offline   Reply With Quote
Old 08-06-2012, 09:37 PM   #33
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
OK, just received my tap turn relay module. Now were the heck is the flasher relay on a BRZ?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 08-06-2012, 11:42 PM   #34
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Fuse box? :shrug:
cobrabyte is offline   Reply With Quote
Old 08-07-2012, 12:09 AM   #35
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Will be checking this out! I do like the additional features of the hazard lights too!
Was raining down hard today, was wishing I had the F1 style rear-fog going!
eriktherod is offline   Reply With Quote
Old 08-07-2012, 12:49 AM   #36
sesmls
Drives: DGM BRZ Limited, 05 Baja Turbo
With your head under the steering wheel, the flasher sits just below the steering column, just to the left. It's an 8-pin Toyota-style flasher, and the wire harness faces the firewall.
I know this because I can no longer hear factory turn signals, so had to replace mine with a louder one...
sesmls is offline   Reply With Quote
Old 08-07-2012, 05:38 AM   #37
BMWDavid
So, can you get at it without removing any panels?
2005 Honda XR650L
2006 VW GTI/DSG
Old 08-07-2012, 07:59 AM   #38
Paragon
Guest
Posts: n/a
A DIY and review of this would be great once someone installs it
Old 08-07-2012, 09:50 AM   #39
sesmls
Yes, it doesn't sit very high up or too forward, so it's easy to unplug it...it's visible and accessible from underneath without removing the plastic panel under the steering wheel. And BTW, I just left the original flasher in place after unplugging it, and used some 3m interior adhesive trim tape to secure the new flasher to a nearby flat surface. Probably if you remove the lower plastic panel you can get easy access to the screw/bracket that holds the flasher in place, but I decided it was easier to just leave the old one where it was -- one less thing to track down if I decide to reverse my installation in the future.
Old 08-07-2012, 11:37 AM   #40
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
Sounds pretty much plug and play right?
Does this device also remotely control the windows or is this just for the tap turn feature?
KRAZYK is offline   Reply With Quote
Old 08-07-2012, 12:01 PM   #41
BMWDavid
I'll give this a try. Might not be able to twist and get in that position (old fart, 57 with blown back) to find it.
2005 Honda XR650L
2006 VW GTI/DSG
Old 08-07-2012, 12:40 PM   #42
cobrabyte
cobrabyte's Avatar
Installed. Awesome little module. Does different hazard modes, as well. Could get in trouble with that wig-wag pattern.
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
FINALLY My Turn! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 10 06-12-2012 12:52 AM
