09-05-2015, 09:24 AM | #281 | |
09-05-2015, 10:17 AM | #282 |
Drives: World Rally Blue BRZ
When I checked the bearing part number, it was the same as the Forester's bearing part.
The Following User Says Thank You to Brzerker For This Useful Post: | solidONE (09-05-2015) |
09-08-2015, 01:02 AM | #283 |
Drives: FR-S Whiteout
Looks like I'll have to "escalate" the case with Toyota not honoring their warranty. Hopefully some of the fold that already had the repairs done under warranty will give me a hand. @ravenstig @tunami @tracerit @xlid007 @MastasmurF @LavosTRD
I will be contacting the national office to let them know about this common defect including my case that was denied warranty.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 09-08-2015 at 01:17 AM. |
The Following User Says Thank You to solidONE For This Useful Post: | gonzo (11-05-2015) |
09-08-2015, 04:28 PM | #284 | |
Drives: 2013 FR-S 6spd Whiteout
09-08-2015, 09:37 PM | #285 |
It's actually already finished, but I'm trying to get reimbursed for the money I paid.
Intent > Content
cowardice is the mother of cruelty. |
09-09-2015, 04:53 AM | #286 | |
Drives: BR86
I cleaned the two mating points before re-greasing with the hi-temp stuff & I noticed the fork appears coated/painted but the contact point seemed scuffed & a little corroded which might explain the squeak. Thank You for this informative & effective solution - I hope it lasts another 2.5 years. ps: clutch actuation now also smoother |
09-09-2015, 01:11 PM | #287 | |
義理チョコ
I've observed that simply pulling the fork forward and swinging the whole assembly in a direction it doesn't normally see seems to at least temporarily quiet down the squeak. I'm guessing some existing lubricant is picked up and spread around when we do this. @Decay107, it is time for us to get on the DIY. Can't do it this weekend but hopefully next. How's your schedule?
The Following User Says Thank You to Ultramaroon For This Useful Post: | Sigh-on-Rice (09-09-2015) |
09-09-2015, 10:36 PM | #288 |
Drives: BR86
I will keep you guys posted if it all goes pear shaped, but for now it's excellent.
The Following User Says Thank You to ZZT86 For This Useful Post: | Ultramaroon (09-09-2015) |
09-10-2015, 03:06 AM | #289 | |
Turning is for Nerds
Drives: 35 characters is not enough
The Following User Says Thank You to Decay107 For This Useful Post: | Ultramaroon (09-10-2015) |
09-10-2015, 03:37 PM | #290 |
Just drive it
Drives: 13' FR-S
I've been having same issue for quite a bit now. I tried to remove the rubber dust boot that's around the clutch fork, but didn't work. I used lithium grease spray can with straw on it to squirt small bit of grease on front and back side of clutchfork, just enough so that the grease can run down and touch the pivot point. Now the squeak is gone.
09-11-2015, 09:47 AM | #291 |
Drives: Whiteout FR-S
Rained yesterday for first time in a week or so and the noise came back. It was still raining this morning and the noise was just as loud. So I should assume the noise is somehow related to rain, water, or general dampness.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
09-14-2015, 08:36 PM | #292 |
Waited 5 years for this
Drives: '18 MX-5 Club
Lubing the pushrod inside of the slave cylinder got rid of the noise. Is this what Ultramaroon and Dacay107 are planning on making DIY for? I'm also surprised that the tech service said there is no other reports of clutch squeak noise. |
09-15-2015, 12:22 AM | #293 |
義理チョコ
Hmmmm... Mine is lubed. Still planning on dropping the trans for this.
09-15-2015, 02:25 PM | #294 |
Stuck like Glue
Drives: WRB BRZ Limited
I started hearing this noise on my vehicle a couple of weeks back too. At first I thought it was something temporary and it will give away (noise was very faint). I then did some research online and found this thread.
The noise on my vehicle has been the same (attached video) for the past 2 weeks. I'm not able to reproduce the noise at all times and have been a little hesitant to take it to the dealer for the same reason. I'm not sure under what conditions I can reproduce the noise consistently as I have heard the noise after driving around for some time, after a cold start and when the vehicle is parked with the engine idling, but never consistently. After reading the majority of this thread I see that this issues is being linked to the throwout bearing/clutch plate. Is there anything else I can check from my end before taking it to the dealership? I have 38k miles on my vehicle but I have the extended powertrain warranty on it too. So hopefully, this should be covered under warranty. Last edited by ZeHeadBanger; 09-15-2015 at 03:21 PM. Reason: Updated the video URL title |
Similar Threads | ||||
Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
