Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-14-2013, 09:13 AM | #15 |
Drives: Subaru BRZ Limited, Red
My transmission has improved as I've put miles on the car. I'm at about 6000 miles and the transmission is as smooth as most cars I've owned except for my Hondas. For normal highway driving, I frequently skip gears; going from 3rd to 6th when I'm accelerating to 55 mph traffic. The 6th to 3rd down shift is also nicely spaced when braking for a tight corner. After all, 3rd is good for nearly 80 mph and the lower gear offers a lot of flexibility in controlling entering speed and exit speed.
05-14-2013, 10:23 AM | #16 |
Drives: 13' DGM Built FBM BRZ
Only problems i have is if im trying to accelerate between gears sometimes at high speed seems like the gear shifting gets "stuck" and force needs to be put into it. Is that normal?
05-14-2013, 04:01 PM | #17 |
High vehicle speeds, or really fast shifts?
05-14-2013, 04:35 PM | #18 |
Toyota Soul
Drives: 96 taco
Accelerate between gears?
No replacement for Displacement??? Tell that to the people with a 2JZ.
06-07-2013, 12:38 PM | #19 |
Chief
Drives: 2013 DGM BRZ Premium 6MT
Anyone experience an issue where you go WOT in 3rd or 4th gear and then shift into 6th gear? The issue being that when you try to go into 6th gear, it grinds a bit. In my previous vehicles, I do not ever recall having an issue skipping gears and hearing it grind at the same time. I know part of the solution is to not skip gears, but I was just curious as to if anyone else had had this issue.
06-07-2013, 01:51 PM | #20 | |
Drives: Attitude
06-08-2013, 12:29 PM | #21 |
Drives: Pavement MT GR86
Only happens to me if you shift it fast...if your skipping you're not in a hurry to be in 6th so just slow shift.
Anyone else have my issue with 3rd? The gate seems odd compared to the other gears on upshift but not downshift
GR86 MT premium
06-08-2013, 12:41 PM | #22 | |
Drives: WRB BRZ Sport Tech
06-08-2013, 10:06 PM | #23 | |
Chief
06-08-2013, 10:19 PM | #24 |
I hear ya, I do the same, but I was only suggesting that instead of releasing the clutch between each gear, just row the gears with the clutch in until you get to the gear you want, bump the rpm and release the clutch. Voila, skip shifting without the harm to your syncros.
06-10-2013, 08:25 AM | #25 | |
Chief
Similar Threads | ||||
manual transmission issues | XtremeMaC | Engine, Exhaust, Transmission | 4 | 10-10-2012 06:40 PM |
Transmission issues... | Rob_g | Issues | Warranty | Recalls / TSB | 13 | 09-23-2012 07:40 PM |
How do you stop your car? (Manual Transmission) | pinoyplaya | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 08-25-2012 11:44 PM |
Which transmission do you have ? Manual or Automatic ? | PRO Import Tuners | Engine, Exhaust, Transmission | 14 | 08-24-2012 09:21 AM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
