07-11-2016, 01:48 AM | #897 | |
Drives: GTS 86
This might be true, however our cars are RHD so the steering pinion/shaft are on the other side (right in the bloody way) therefore there is a really small space to play with hence we lift the engine up to create a bit more wiggle room! |
The Following User Says Thank You to Hawk77FT For This Useful Post: | Reamer (07-11-2016) |
07-11-2016, 01:48 AM | #898 | ||
Drives: 2012 FR-S
Also not recommended that you jack from oil pan. Best if the block of wood is placed on the cast alloy block or cam chain cover. Instructions here: http://aceheader.com/images/Removal_..._of_Header.pdf Quote:
Any questions regarding installs, feel free to PM us or send us an e-mail at ace@bymer.com.tw Take care |
07-12-2016, 03:03 AM | #899 |
Drives: Toyota 86 GTS Auto
I've got everything done; header is installed, tune is applied. Sounds very nice, goes very nice. 0-100 is down to 7.3s (AT). I like this
There's one thing bugging me; the pipe actually touches the bottom plate. What do you guys recommend, how to best address this? |
07-12-2016, 03:10 AM | #900 | |
Drives: 2012 FR-S
1. Remove skid plate 2. Place block of wood on bottom of skid plate 3. Hammer the raised section until flat This should take care of the contact. Glad to hear the install and tuning went well |
The Following User Says Thank You to AceHeader-MT For This Useful Post: | ysu (07-12-2016) |
07-12-2016, 04:02 AM | #901 | |
You're lucky you discovered it only after a day or so. |
The Following User Says Thank You to Wayno For This Useful Post: | ysu (07-12-2016) |
07-12-2016, 06:13 AM | #902 |
I'm not that good, mind you, I have been tipped off by a friend
Attached pic, this is what it looks like. |
07-12-2016, 06:16 AM | #903 |
Weight Weenie
Drives: 15 FR-S
07-12-2016, 10:00 PM | #904 |
Drives: GTS 86
07-15-2016, 02:26 PM | #905 |
That Guy
Drives: 2013 asphalt FRS MT
I'm getting my header installed next week. I was just reading through the instructions and I have a few questions.
1) How long would it take a competent shop to install this? 2) What are guys using for the midpipe to front pipe gasket? 3) Do I really need to remove the front pipe if I'm reusing the stock one? Thanks. |
07-15-2016, 03:46 PM | #906 | |
2. OEM donut 3. Yes. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Calum (07-15-2016) |
07-15-2016, 04:04 PM | #907 |
That Guy
07-16-2016, 12:31 AM | #909 |
The Fail Boat
Drives: CWP S.B.
If you are just on oem catback it's totally fine, but if you got any aftermarket catback (especially the ones don't use the spring bolt) or you just took it on & off many times then you should get a new one. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to chaoskaze For This Useful Post: | Calum (07-28-2016) |
07-28-2016, 12:06 PM | #910 |
Drives: 2012 FR-S
Just to toss this out there: the big boys down at Harrop Engineering have chosen the Anaconda 48 for World Time Attack... just saying...
Big boys play with big toys #trackrecord #aceheader |
Similar Threads | ||||
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
