Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-14-2012, 04:22 PM | #1 |
Light flashing under trail braking.
The light next to the shift light in the upper right of the tach flashes whenever I try to trail brake. The same light stayed on solid when our BRZ was on the dyno, and went off as soon as we started driving normal after the dyno session, so the light is definitely directly related to wheel speeds/wheel speed sensors. I have both traction and stability control fully off. Does anyone know how to eliminate this? It's interfering with trail braking, and forces the car to understeer instead of rotating the car how I want it to. *disclaimer* this is for track use. |
08-14-2012, 05:32 PM | #2 |
Kouki-Monster
Did you hold the TC button down for 5 seconds? When I did that I was free to do as I please
Rich Anderson
EMPOWER AUTO |
08-14-2012, 08:17 PM | #3 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
08-14-2012, 09:16 PM | #4 |
VehicleDynamicsSpecialist
Drives: iG FR-S
If it's turned fully off you can do as you wish. It will still light up but won't interfere.
08-14-2012, 10:38 PM | #5 | |
08-15-2012, 12:17 AM | #6 |
Drives: iG FR-S
Will it lift-throttle oversteer?
I'm not being a ****.. But you aren't asking for too much steering input are you? Ie, are you causing understeer? |
08-15-2012, 12:21 AM | #7 |
Drives: iG FR-S
Maybe it's just the elec. brake controller?
08-15-2012, 08:44 AM | #8 |
Corner Junkie
I haven't tested it yet, but it might flash when the ABS is engaged also..
The only other thing I can think of might be the SSmart Stop or whatever it's called. Are you deep into both the gas and brake at these points on the track? |
08-15-2012, 01:26 PM | #9 | ||
Yes, I'm "causing" the understeer, but the car is understeering in a scenario where it should be rotating. The understeer is a symptom of the braking system not allowing me to do what I want. If I brake at 90% of the limit of the tires, then I can get more simultaneous rotation and braking out of the car than if I try to brake at 100%. |
The Following User Says Thank You to CSG Mike For This Useful Post: | ill86 (08-15-2012) |
08-15-2012, 02:28 PM | #10 |
Corner Junkie
I'm not sure about the light, that will take some playing around. I'll have to try to remember to see if I can get the light flashing at the next AutoX. It still might be the Smart Stop or whatever. Though trail braking isn't really the place where you'd be hard on both pedals.
As for the car's behavior, perhaps it has a lot more front bias than you are used to? You might be asking too much of the front tires without realizing it. Dunno. |
08-16-2012, 10:20 AM | #11 |
Corner Junkie
Well, seems like it's the EBD, I'm really surprised and I wonder what it's trying to do.
08-16-2012, 12:44 PM | #12 |
form follows function
Drives: RIP '13 BRZ
08-16-2012, 02:39 PM | #13 |
But the end result is that braking distance is actually increased... we're talking like 30% increased...
08-16-2012, 04:03 PM | #14 |
drift
I felt this several times yesterday on a bumpy canyon road, I would jab the brake on entry or mid-turn to make a correction and the car would "release" the brakes and point the car straight. Not a good feeling! will have to try pulling the ABS fuse next time to see if that helps.
Similar Threads | ||||
Toxic Detail and Performance, Indian Trail NC | Toxic | Announcements, Contests, Giveaways | 4 | 07-24-2012 05:13 PM |
Turn signal amber LED's flashing quickly | michaelahess | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-13-2012 10:55 PM |
anybody else see the flashing carrot??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-18-2012 09:25 AM |
Help me track down my braking problem :( | #87 | Other Vehicles & General Automotive Discussions | 32 | 09-26-2011 12:49 PM |
How much do you like heel-toeing or left foot braking? | USMCMike | Other Vehicles & General Automotive Discussions | 20 | 01-15-2010 04:20 PM |
