Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 05-17-2017, 06:01 PM   #85
cevin45x
cevin45x's Avatar
Drives: '13 BRZ Limited
Thanks for the feedback! I have sti mounts now, along with the sti trans mount and I feel that they are no different from OEM. Wanting something in between cusco/torque solutions and the sti ones since I have all Whiteline bushings on my car. Need something to complete all the bushings I've added.
When you say gummy, are they physically softer (significantly) when they were originally?
With your sti mounts now are they stiffer than the "gummy" perrins?
Thanks
'13 BRZ Limited - CBS MT
STX Build - OFT Stage 2 EL 93oct (etune)/TRD intake/HKS EL catless/Motiv OP/Invidia FP catted/Perrin CBE resonated/All complete Whiteline bushings/MTEC trans & clutch springs/Kartboy SS & mount/Perrin 19mm f & 16mm r/Perrin crank & assessory pulleys
cevin45x is offline   Reply With Quote
Old 05-18-2017, 02:40 PM   #86
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Thanks
Both are soft on the side that faces the primary. Also the internal structure has loosened up quite a bit, to the point where I can get some movement with my hand.
The STI are noticeably stiffer than both OEM and gummy Perrins.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
cevin45x (05-18-2017)
Old 08-10-2017, 12:04 PM   #87
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by Koa View Post
Hey guys, want to necro this and point people to a possible, low cost solution.
DIY is here
@PERRIN @PERRIN_Chris
@FT-86 SpeedFactory @Evasive Motorsports @Sportsguy83 @tg_1981 @FrX @brz2013
what did you do here? photobucket messed up
BRZ RN is offline   Reply With Quote
Old 08-11-2017, 10:42 AM   #88
-Phil
Drives: Rb25 neo brz
It's not messed up. photo bucket requires users to pay for hosting as of now.
-Phil is offline   Reply With Quote
Old 08-11-2017, 06:12 PM   #89
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
a yeah that one. im being tuned by your shop remotely from 20853 MD, any recommendations for engine mounts? thanks.
Old 08-14-2017, 10:08 AM   #90
-Phil
I would try and find a set of brz/frs STI mounts, i used those for a long time with no issues.
Old 10-30-2017, 12:56 AM   #91
Koa
Sweeper
Koa's Avatar
Hey BRZRN my broh,
I took a bit of a hiatus from FT86! My girl is running like I want her and just haven't been active.
I tried to find my photos but they aren't in any of my externals, none of my rigs, and photobucket apparently deleted my account when they made the switch to SaaS. I shoulda listened to their emails going on for months saying they would,
Anyway, Here's the only pic I could find. Shame. I'm a python-crazy data architect and can't find some old pics.. musta.. burned 'em.
ha ha. get it. perrin motor mounts melti- what?!
The general approach in the DIY is the same, though. In a nutshell, cut those inferno guards into a shape that you can wrap around & fasten to the perrin motor mount, underneath the flange. I personally used metal zipties - muffler zips. I looked under momo the other month when I was changing her tranny fluid and them mounts look brand new.
I love perrin's stuff. Chris is a good guy. Haven't steered me wrong in any of my subi builds
Enjoy, have fun, good luck!
Old 11-02-2017, 03:43 PM   #92
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Hey BRZRN my broh,
I did STi motor mounts for a local and he actually saw this thread. I made some small plates that sandwich between the motor mount and the subframe with a tab. The sheild folds around the mount on the header side, two pop rivets per side, line with DEI reflect a gold.
Took about a half hour with some spare sheet metal, tin snips, and HF rivet gun.
Iirc he had a SBD kit and the header was not super close to the motor mount, but anything you can do to reflect heat away from rubber/poly mounts, oil, gas, and intake charges is a good idea.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
perrin engine mounts
Perrin or Cusco Engine Mounts and NVH APS86 Engine, Exhaust, Transmission 7 08-04-2018 02:08 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
engine mounts for FI jamesm Forced Induction 19 04-18-2013 08:57 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
