#1373 | |
Drives: 2013 Cayenne turbo
I found if I got above 65 degrees C for a surface temp of the ZIIs, they started going off. (Sorry, I'm an engineer, so metric is all I know anymore.) Invest in a garden sprayer and drive the tires until they start getting the greasy feeling. Then spray them down heavily and make another run. You'll see what I mean.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1374 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
38f/32.5r on concrete on 235/40/17 Z2s
#1375 | |
Drives: 2014 SWP BRZ Limited
#1376 |
Dodging cones
I run them in Florida's crazy heat, with 2 drivers. We spray. A lot. And then we spray again. We went through just over 3 gallons of water for 14 runs yesterday
However, I still stand by the fact that I believe they are the tire you want a camber challenged car.
#1377 | |
Anyone have some suggestions on which mods to go for first with the car? I intend on getting everything allowed in the C Street class but don't really know which ones offer the most bang for the buck. So far I only have wheels/tires. |
#1378 | |
Seat time and alignment and air pressure adjustments should be enough to get you learning. Then decide what the car needs. Saying you will do everything that CS allows is just going to eat at your wallet when the biggest restriction is the operator, not the vehicle.
Chris
#1379 | |
Dodging cones
#2 Crash bolts + alignment (~$125) #3 Front sway bar (I recommend Strano or Whiteline) (~$200) #4 brake pads and fluid, prefer DS2500 as do many here with ATE fluid ($280) #5 shocks, Koni are most affordable. ($700 plus another alignment) #6 catback exhaust Throw in a $50 airfilter whenever you can spare the $50, not crucial But listen to the Bimmer guy above me first. That is more important that all. A good driver on the OEm tires can even outdrive an ambitious newbie on a full prep car.
#1380 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#1381 |
Dodging cones
I mean get an after market air filter, whenever you feel like throwing $50 at ~1hp gain. I use the aFe Dry as I won't buy oiled.
#1382 |
Lost in Kansas
#1383 |
Dodging cones
Hahaha, I was wondering what was unclear. I kept reading it over and over, trying to figure out where I messed up lol
#1384 | |
(And the crashbolts depending on how afraid you are of driving without a professional alignment) ..but other than that, I really feel like you're better off NOT buying anything else. Not from a money standpoint, but so you can just concentrate on your driving. I spent 5 years in my WRX chasing handling characteristics, checking tire temps and adjusting dampers that I really think I distracted myself from actually driving. In the ~20 events I've done in the BRZ I've only even checked tire pressures a handful of times and I'm a much better driver for it.
#1385 | |
#1386 |
Dodging cones
Eh, I'd say you're 95% correct. I'd argue tire PRESSURES are worth checking and resetting between runs IMO. Tire wear and consistency of the car's performance. However temperature, shock settings, etc are definitely best left until you have a very firm grasp on your driving.
And crashbolts and alignment are more about tire life too. That -1 degree will help save tirelife.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
