Sam Strano
Old 08-17-2014, 09:41 PM   #1373
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Originally Posted by marc615243 View Post
I just got a set of these and am curios as well, I am new to autocrossing so I am trying to absorb as much info as I can before each run
Seeing how you are in one of the hottest temperature areas, you will have to spray ZIIs between runs. They do not tolerate heat as well as other tires can, but other tires lack performance that the ZII has.
I found if I got above 65 degrees C for a surface temp of the ZIIs, they started going off. (Sorry, I'm an engineer, so metric is all I know anymore.) Invest in a garden sprayer and drive the tires until they start getting the greasy feeling. Then spray them down heavily and make another run. You'll see what I mean.
bimmer635csi is offline   Reply With Quote
Old 08-17-2014, 09:55 PM   #1374
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
38f/32.5r on concrete on 235/40/17 Z2s
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-17-2014, 10:04 PM   #1375
marc615243
marc615243's Avatar
Drives: 2014 SWP BRZ Limited
Thanks for the info, I will keep this in mind.
marc615243 is offline   Reply With Quote
Old 08-18-2014, 07:28 AM   #1376
Kido1986
Dodging cones
Kido1986's Avatar
I run them in Florida's crazy heat, with 2 drivers. We spray. A lot. And then we spray again. We went through just over 3 gallons of water for 14 runs yesterday
However, I still stand by the fact that I believe they are the tire you want a camber challenged car.
Old 08-18-2014, 06:48 PM   #1377
marc615243
marc615243's Avatar
Thanks for the info! I have a 3 gallon bottle that I will load up to keep my tires cool.
Anyone have some suggestions on which mods to go for first with the car? I intend on getting everything allowed in the C Street class but don't really know which ones offer the most bang for the buck. So far I only have wheels/tires.
Old 08-18-2014, 07:49 PM   #1378
bimmer635csi
I just placed 2nd in CS (including a couple of Nissans) with only tires and crash bolts.
Seat time and alignment and air pressure adjustments should be enough to get you learning. Then decide what the car needs. Saying you will do everything that CS allows is just going to eat at your wallet when the biggest restriction is the operator, not the vehicle.
Old 08-18-2014, 10:48 PM   #1379
Kido1986
Dodging cones
Kido1986's Avatar
#1 Tires ($800)
#2 Crash bolts + alignment (~$125)
#3 Front sway bar (I recommend Strano or Whiteline) (~$200)
#4 brake pads and fluid, prefer DS2500 as do many here with ATE fluid ($280)
#5 shocks, Koni are most affordable. ($700 plus another alignment)
#6 catback exhaust
Throw in a $50 airfilter whenever you can spare the $50, not crucial
But listen to the Bimmer guy above me first. That is more important that all. A good driver on the OEm tires can even outdrive an ambitious newbie on a full prep car.
The Following 3 Users Say Thank You to Kido1986 For This Useful Post:
bimmer635csi (08-18-2014), BRZ21 (08-19-2014), rs999 (08-20-2014)
Old 08-19-2014, 09:06 AM   #1380
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
What is this?
DylanFRS is offline   Reply With Quote
Old 08-19-2014, 09:07 AM   #1381
Kido1986
Dodging cones
Kido1986's Avatar
Originally Posted by DylanFRS View Post
What is this?
I mean get an after market air filter, whenever you feel like throwing $50 at ~1hp gain. I use the aFe Dry as I won't buy oiled.
Old 08-19-2014, 09:56 AM   #1382
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Oops, for some reason I read that as "airlifter". I am getting too lazy to actually bother reading.
Old 08-19-2014, 10:02 AM   #1383
Kido1986
Dodging cones
Kido1986's Avatar
Hahaha, I was wondering what was unclear. I kept reading it over and over, trying to figure out where I messed up lol
Old 08-19-2014, 10:19 AM   #1384
qoncept
qoncept's Avatar
Agreed, but I would say, if you can at all afford it, buy the tires. They are 90% of your prep so you'll have a much, much better idea of what your actual performance is, plus you'll have a lot more fun.
(And the crashbolts depending on how afraid you are of driving without a professional alignment)
..but other than that, I really feel like you're better off NOT buying anything else. Not from a money standpoint, but so you can just concentrate on your driving. I spent 5 years in my WRX chasing handling characteristics, checking tire temps and adjusting dampers that I really think I distracted myself from actually driving. In the ~20 events I've done in the BRZ I've only even checked tire pressures a handful of times and I'm a much better driver for it.
qoncept is offline   Reply With Quote
Old 08-19-2014, 10:25 AM   #1385
qoncept
qoncept's Avatar
Old 08-19-2014, 11:00 AM   #1386
Kido1986
Dodging cones
Kido1986's Avatar
Eh, I'd say you're 95% correct. I'd argue tire PRESSURES are worth checking and resetting between runs IMO. Tire wear and consistency of the car's performance. However temperature, shock settings, etc are definitely best left until you have a very firm grasp on your driving.
And crashbolts and alignment are more about tire life too. That -1 degree will help save tirelife.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
