JonMotoring
Old 10-16-2012, 02:32 AM   #1345
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
My basic understanding of airfoils (from my high school aeronautics engineering class, and being that I work on airplanes) is that if air has to travel farther OVER an airfoil then it moves Faster, causing low pressure, and therefore Lift. Causing the car to Lift is the exact opposite, obviously, of what we want to do. I'm not necessarily looking for downforce, but just to smooth the airflow under the car to reduce drag, which would increase top speed AND fuel economy.
Talking about airfoils in the aircraft context is tricky, since not all of an aircraft's lift is generated through Bernoulli's Principle.
You're right that faster (i.e. lower pressure) airflow will cause an airfoil to lift, due to the difference in pressure (low pressure fast air on top and high pressure slower air on bottom). Many cars exploit this effect in reverse, the air above the car is higher pressure and the air below is made to flow faster and thus be lower pressure. As you can imagine, the effect is also reversed, meaning that instead of lift the pressure difference will generate downforce.
On the FR-S/BRZ underbody panels won't generate lift, but they probably won't generate too much downforce either. However, they do appear to lower the coefficient of drag on the JDM version that comes with mostly complete underbody paneling from factory. (see http://www.ft86club.com/forums/showthread.php?p=451112) This should result in increased fuel economy. This article (http://www.edmunds.com/fuel-economy/...l-economy.html) suggests maybe .2 mpg for that .01 improvement in Cd, even if it's more or less, that gives you an idea of the magnitude of the improvement. As far as top speed goes, using the formula of WHP = .000007*Frontal Area*Coefficient of drag*velocity^3 (see note) we find that Cd = .29 results in a theoretical top speed of 156.204mph and a Cd = .28 results in an increase to 158.042mph. With a lip spoiler and underbody panels the JDM GT-86 gets the Cd down to .27 which gives a theoretical top speed of 159.97mph. Except that it's in Japan and they use kph, so 257.4
*Note: I used the values of whp = 173 (based on Edumunds.com independent dyno run) and Frontal area = 22.36 ft^2 (spec sheet width x (height-ground clearance), which is imperfect but kinda close)
Old 10-16-2012, 02:37 AM   #1346
gmookher
If you have a tune file, I will be in PHX next weekend, at the track in chandler, can bring laptop and cable.
gmookher is offline   Reply With Quote
Old 10-16-2012, 02:41 AM   #1347
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Well ill be heading to Cali this week and will be back before the weekend... My ? is, do i buy the tune and no license or what? John's thread on the Visconi Tune says that you buy license and then tune and a cable is a option (correct?) if you have a buddy near by that has one which would be you from you mentioning you received yours.....
SMOKETREES is offline   Reply With Quote
Old 10-16-2012, 02:42 AM   #1348
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Do i just buy the tune and basically i receive a e-mail with a tune file? and i dont need license?
Old 10-16-2012, 03:31 AM   #1349
Yruyur
Yruyur's Avatar
You will need the file and license then borrow my cable once I get it. Could test drive my car first.
The Following User Says Thank You to Yruyur For This Useful Post:
SMOKETREES (10-16-2012)
Old 10-16-2012, 11:32 AM   #1350
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Okay thanks. ?'s were answered = ). and ill have to actually take you up on that offer now since i am looking into the tune very very badly
Old 10-16-2012, 01:10 PM   #1351
gmookher
tune and license is all emailed to ya
Old 10-16-2012, 02:03 PM   #1352
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Cool let ya know once I put up the $ and get it Mook
Thx
Old 10-16-2012, 02:21 PM   #1353
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Just found out the gt86/fr-s is only one of three new sports cars in the work at Toyota one is going to be a mr2 style 2 seat convertible to compete with the mx5 and the other a v6 n/a to compete with the 370z it was on top gear in the Philippines when they interviewed a guy from Toyota
Sent from my SGH-T989 using Tapatalk 2
Old 10-16-2012, 02:41 PM   #1354
Yruyur
Yruyur's Avatar
Yeah there was a thread on it the other day. Mr2 & Celica. Which is interesting as I would think the frs would replace the Celica and be the middle of the Mr2 and the supra that has been rumored.
Old 10-16-2012, 03:04 PM   #1355
Accurate Race Shop
Drives: Scion FR-S
Well I guess im behind the times I thought it was new they where making 3 instead if just one it sounds like over kill to me almost like they are trying to compete with Chevy or dodge for having multiple sports cars out at once
Old 10-16-2012, 03:34 PM   #1356
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
They are trying to compete with GM, Toyota and GM are number 1 & 2 in the world (depending on what day of the week it is). So anything Toyota does is to become number 1 and stay there. Besides, more sports cars means more money for Toyota and possibly more money into this economy.
Sent from...somewhere?
Old 10-16-2012, 03:47 PM   #1357
Accurate Race Shop
Drives: Scion FR-S
I agree its going to be a good thing but I would like to see a lasting affordable sports car like the Camaro or the mustang from Toyota I think the fr-s has the potential to be around for a good long time one they get it figured out and I know the Camaro went away for a few years but the customers complained so now its back. Ford has the mustang for the average person and the gt50 for the crazy rich. Toyota could use the same formula with the fr-s and the lfa. Just my thought on it
Old 10-16-2012, 03:51 PM   #1358
BRZ_Driver
BRZ_Driver's Avatar
Drives: 2013 Subaru BRZ
Who is is going to the pavilions. So far it's me and brz driver
Sucks that I made it out so late. Didn't think the errand I was running would take so long.
Christian
1977 280Z(Fidelity) L28ET powered at 10psi
2013 Subaru BRZ w/6M(Vader) BWR Turbo Kit in the works
BRZ_Driver is offline   Reply With Quote
