AVOturboworld
Old 11-05-2012, 01:19 PM   #1331
2forme
Originally Posted by AVOturboworld View Post
We will be arranging for that.
Being based on the West Coast, all we generally have access to is 92 octane ethanol blend. We have sourced some 92 octane non-ethanol, and have already started on 93 maps based on that. Even the 92 non-ethanol "pure" gas allows it to run much richer than the 92 ethanol blends, and is giving us much better data points to base the tuning on for the other parts of the country. I'm estimating we've already picked up an additional 10-15whp from the pure gas.
If you guys need someone to test/tune a kit on 93 or even 94 octane, let me know... I have access to both and already have the ECUTek kit/license.
Old 11-05-2012, 02:59 PM   #1332
sw20kosh
Drives: 2013 Black FR-S
Paul,
I am curious as to why you think the turbo got much "laggier" when looking at the japan gas dyno vs. 91 octane dyno.
I know you were able to be more aggressive with japan gas but does it really make that big of a difference in the low rpms? 1000 rpm difference in spool time? Usually when switching to higher octane I see big increases in the top end, not the bottom end.
For a street kit like this I would almost say it would be better to size a smaller turbo for us here in the US. One that spools at 3k rpms not 4k rpms.
Old 11-05-2012, 03:12 PM   #1333
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Gas quality makes a huge difference at any rpm! Especially when you compare ethanol mix gas vs. pure gas. It affects how much timing you can put in at, which effects just how fast it's going to spool up.
But concentrating on that ignores another factor - it's different dyno's. Not different as in different locations/temps, different in that the dyno we use in Japan, a Dynopack, is far more accurate with load than a Mustang dyno, the dyno used in our american run. And the amount of load will directly impact that spool speed. If you look at the Perrin thread, you'll notice they are using a dynopack as well.
On the road, the car would hit peak boost - easily - at 2500rpm in 4th through 6th gear. Even on 91 ethanol-blend octane. That's why we are not worried about a smaller turbo, it's plenty fine at the size it is.
AVOturboworld is offline   Reply With Quote
Old 11-05-2012, 04:04 PM   #1334
sw20kosh
Good to know. I am glad it doesn't feel laggy on the road!
Old 11-05-2012, 08:55 PM   #1335
normanb21
Drives: black frs
I am able to get some 90 non ethanol gas from a station near my home. Would I be able to use this gas with the turbo with one of your maps? I dont have any GOOD tuners near me.
normanb21 is offline   Reply With Quote
Old 11-05-2012, 09:01 PM   #1336
AVOturboworld
90 non-ethanol would be roughly equivalent to 91 ethanol blend, so you'd be ok on the 91 maps.
Old 11-05-2012, 09:27 PM   #1337
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Paul, has any testing been done on 98 PULP in Australia?
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 11-05-2012, 09:37 PM   #1338
Blue86
Drives: Sonic Blue 86GT Manual
Our 98 would be equivalent to the Japanese fuel so the original Japanese tune might be ok for us. Otherwise the US 93 octane tune would be about equivalent for our 98 when they finish that off
Blue86 is offline   Reply With Quote
Old 11-05-2012, 11:38 PM   #1339
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
@AVOturboworld , been following this thread for a while, checking once in a while, and getting really excited seeing the whole kit come along. One thing I'm really curious about is how the kit change the dynamics of the car. I really like the low position of the turbo, keeping the weight nice and low. I've tried searching the 60+ pg thread with all sorts of key words, but without much luck. How much weight does the kit add? Have you guys done any corner weighting (ie weight distribution front-back/left-right).
Also, how much clearance is there between the kit and the skid plate? I feel like I'd want a thicker plate or some bar to protect the turbo.
Old 11-05-2012, 11:51 PM   #1340
AVOturboworld
We've not had time to do corner weight, very honestly. It's not adding that much, though - because we are replacing the exhaust manifold + large cat + heat shielding with our lighter exhaust manifold + turbo, the weight gains there are not large. Maybe another 5lbs, and it's in the same location as before. The FMIC will add a few pounds of weight, but thanks to the aluminum construction, is not that heavy. Overall effect to the balance is minimal, honestly.
What does change is how ferociously quick it is. We had a quick 1-2-3 pull with a 400 odd whp turbocharged wagon that is much heavier than the FR-S, and even with us two, uh, chunkies in the front seat + boatload a gear, walked away from him.
I'm also not sure where all this worry about mid-corner histrionics that a turbo is supposed to add to this car. That's a left-over from the old Porsche Turbo days (which, admittedly, could leave a scar on anybodies memories). There's a reason all the top time attack cars are turbocharged (AWD or RWD), and mid-corner throttle modulation is not an issue there.
Forgot to talk about space. The current size turbocharger has quite a bit of space, it's the exhaust manifold that's the closest to the skid plate. About the same as the OEM exhaust manifold in that regard, if you look under there close, it's almost touching the plate as well.
The Following User Says Thank You to AVOturboworld For This Useful Post:
BigFatFlip (11-06-2012)
Old 11-06-2012, 01:54 AM   #1341
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
Going on the info from Lee, I dont think the first kits are in Aus yet, keen to be the first though!
Bomb3r is offline   Reply With Quote
The Following User Says Thank You to Bomb3r For This Useful Post:
czar07 (11-06-2012)
Old 11-06-2012, 05:28 AM   #1342
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
So the underbody panels are still there? not sure what you mean by heat shielding.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 11-06-2012, 06:52 AM   #1343
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, the underbody OEM panels are still there. The heat shielding he talks about is that the Cat (and I believe the whole header too) has a heat shield that counts as removed weight when you install the AVO unequal length header.
Old 11-06-2012, 07:40 AM   #1344
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
best option to loose weight and avoid fire risk is the ceramic coat instead of shitty heat cloth, which looks like a grandma's pants after a while
I appreciate Paul Hansen is considering this as an option
Cant wait for Stage_2 results!
MSTiFK8R is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
