Old 08-09-2014, 04:45 AM   #1317
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by Trap63 View Post
I think that all genuine parts are a plus but not all parts are real performance parts. You need to observe a strictly non-emotional approach and care for benefits/cost ratio.
You are absolutely right. From owning this car and hearing people with other car brands, most aftermarket parts from the factory are always very minute in terms improvement / change. This is probably so that the original character of the car is preserved, yet the price also seems to be the most expensive when considering benefits/cost ratio.
I think this is why STI never publishes statistical figures, because the avg consumer thinks price is relative to numerical figures and stats (the aftermarket knows this, hence they tend to offer parts that demonstrate big changes). Besides, the factory tuning arm could be the same people that engineered the car to begin with, so they can't really be contradictory to the original car design.
krayzie is offline   Reply With Quote
Old 08-09-2014, 08:42 PM   #1318
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Got my STi sticker a few days ago.
It looks pretty good in person.
I don't know if it's the heat or what, but it keeps peeling up.
Old 08-10-2014, 05:51 AM   #1319
DSOmegaX
DSOmegaX's Avatar
I forgot who it was that installed the draw stiffener, but does instructions come with it? Probably my last major mod on the BRZ for a while I prep a new car purchase haha
@dsomegax.cars
Old 08-10-2014, 07:12 AM   #1320
krayzie
Drive From Home
krayzie's Avatar
It came with lengthy instructions in Japanese. Sorry I threw my packaging away along with the instructions that I translated DOH!
If you can't find the instructions, off my head I can remember most of it:
Basically the left and right rods are oriented differently. The front of the car is towards the top of this pic:
You also need to use a black marker and mark 3mm on the rod away from the damper unit where the o-ring is. The rod allows for a controlled movement of maximum 3mm of the chassis (you might want to consider removing the TRD door stablizer cuz of this). This mark should still be visible after install.
When you set the length of the rods, it only allows for 13mm in variation. The length of the two rods do not have to match if your chassis is aged (mine was installed when the car was relatively new and both rods came out the same set length). The only thing I can't seem to recall is the adjustment range (I *think* it's 350mm to 363mm, if you don't get this right you will damage the frame during use).
The kit comes with a metal bracket and two bolts, you take the center two bolts off the front subframe towards the rear of the car, slide in the bracket with the wings pointing towards the ground to sit in-between the engine cover and the subframe, and replace the two bolts with the longer ones from the kit.
As with the other ends tying onto the side chassis railings, the bolts that would normally hold the transmission cover would need to be installed temporarily while you set the length and bolt everything else down. The very last step of the install is to remove these two bolts, install the transmission cover and then reinstall these bolts.
You should email Japanparts for a copy of the instructions.
Old 08-10-2014, 09:06 AM   #1321
cslntuee
Drives: Subaru BRZ Limited
Which car is your next target? ^^
cslntuee is offline   Reply With Quote
Old 08-10-2014, 01:59 PM   #1322
krayzie
Drive From Home
krayzie's Avatar
I think he said he's getting a WRX.
Meanwhile in the land of the rising sun there is this:
[ame="https://www.youtube.com/watch?v=OxMoFv5FdL4"]WRX S4 開発責任者インタビュー - YouTube[/ame]
http://www.subaru.jp/wrxs4/sp/
Old 08-10-2014, 04:48 PM   #1323
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Looks pretty good, I'm assuming you had to remove the subaru badge for it to fit?
mikeTee is offline   Reply With Quote
Old 08-10-2014, 04:55 PM   #1324
Andrew025
Andrew025's Avatar
It just sticks on top of it.
Old 08-10-2014, 06:56 PM   #1325
DSOmegaX
DSOmegaX's Avatar
Yeah planning to get a WRX. Want to make it a sister car to the BRZ. So with that in mind, planning to get a WRB with the STi lip kit, exhaust, the inevitable pink springs that will be released. Also want to pick up the JDM grille and the fog light housing that gas the DRL bar on them.
The S4 still confuses me, looks like its just their version of the CVT WRX? I plan on getting those wheels though
@dsomegax.cars
Old 08-11-2014, 07:37 PM   #1326
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
Got my STi pink springs today and the ship time wasn't bad at all...now time to install haha...for those that have the springs, did you guys shave the bump stop when installing them?
ModalSoul37 is offline   Reply With Quote
Old 08-11-2014, 09:40 PM   #1327
krayzie
Drive From Home
krayzie's Avatar
http://www.m3post.com/forums/showpos...29&postcount=1
Old 08-12-2014, 12:08 AM   #1328
ModalSoul37
Good read, but still don't know if I should shave...a friend mentioned it and tbh never even thought about doing it
Old 08-12-2014, 01:08 AM   #1329
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I cut mine.
Old 08-12-2014, 02:50 AM   #1330
ModalSoul37
Originally Posted by Turbo95eg6 View Post
I cut mine.
Thanks for the feedback...I was excited for the install but I think japanparts messed up my order...I ordered one pair each of the front and rear springs, but both of the boxes have the same part number...are the springs interchangeable? I imagine that they aren't.
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
