#1317 | |
Drive From Home
Drives: BRZ STI Performance
I think this is why STI never publishes statistical figures, because the avg consumer thinks price is relative to numerical figures and stats (the aftermarket knows this, hence they tend to offer parts that demonstrate big changes). Besides, the factory tuning arm could be the same people that engineered the car to begin with, so they can't really be contradictory to the original car design. |
#1318 |
Drives: Neptune GR86
Got my STi sticker a few days ago.
It looks pretty good in person. I don't know if it's the heat or what, but it keeps peeling up.
#1319 |
I forgot who it was that installed the draw stiffener, but does instructions come with it? Probably my last major mod on the BRZ for a while I prep a new car purchase haha
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#1320 | |
Drive From Home
If you can't find the instructions, off my head I can remember most of it: Basically the left and right rods are oriented differently. The front of the car is towards the top of this pic: ![]() You also need to use a black marker and mark 3mm on the rod away from the damper unit where the o-ring is. The rod allows for a controlled movement of maximum 3mm of the chassis (you might want to consider removing the TRD door stablizer cuz of this). This mark should still be visible after install. When you set the length of the rods, it only allows for 13mm in variation. The length of the two rods do not have to match if your chassis is aged (mine was installed when the car was relatively new and both rods came out the same set length). The only thing I can't seem to recall is the adjustment range (I *think* it's 350mm to 363mm, if you don't get this right you will damage the frame during use). The kit comes with a metal bracket and two bolts, you take the center two bolts off the front subframe towards the rear of the car, slide in the bracket with the wings pointing towards the ground to sit in-between the engine cover and the subframe, and replace the two bolts with the longer ones from the kit. As with the other ends tying onto the side chassis railings, the bolts that would normally hold the transmission cover would need to be installed temporarily while you set the length and bolt everything else down. The very last step of the install is to remove these two bolts, install the transmission cover and then reinstall these bolts. You should email Japanparts for a copy of the instructions.
#1321 |
Drives: Subaru BRZ Limited
#1322 |
Drive From Home
I think he said he's getting a WRX.
Meanwhile in the land of the rising sun there is this: [ame="https://www.youtube.com/watch?v=OxMoFv5FdL4"]WRX S4 開発責任者インタビュー - YouTube[/ame] http://www.subaru.jp/wrxs4/sp/ |
#1323 | |
Yup.
Drives: MT Subaru BRZ '13
Looks pretty good, I'm assuming you had to remove the subaru badge for it to fit? |
#1324 |
It just sticks on top of it.
#1325 | |
The S4 still confuses me, looks like its just their version of the CVT WRX? I plan on getting those wheels though
@dsomegax.cars
#1326 |
Drives: 2014 Limited WR Blue Brz
Got my STi pink springs today and the ship time wasn't bad at all...now time to install haha...for those that have the springs, did you guys shave the bump stop when installing them?
#1327 | |
Drive From Home
#1328 | |
#1329 |
Drives: 2014 BRZ SWP LTD
#1330 |
Thanks for the feedback...I was excited for the install but I think japanparts messed up my order...I ordered one pair each of the front and rear springs, but both of the boxes have the same part number...are the springs interchangeable? I imagine that they aren't.
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 05:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 10:30 AM |
