Old 08-29-2013, 07:34 PM   #1317
sw20kosh
Drives: 2013 Black FR-S
Tested the Borla EL header. No increase in power from bolting it on. A re-tune may have done something as there is no more cat restriction causing heat build-up but time was ticking on the dyno and I wanted to get the small pulley in for as much tuning as possible. So we put the pulley on and started tuning.
Did a bunch of prelim dyno tuning with @moto-mike testing the smaller pulley on CA pump with water meth inj. I am registering an increase of 3 peak psi. The top end is still being worked out but basically 20-25 ft lbs of torque everywhere vs the stock pulley. More to report soon.
Old 08-29-2013, 09:26 PM   #1318
diss7
Drives: AE86, 2x GT86, TE27
My supercharger is getting installed today.
Had a call before. Mechanic doesnt believe pulley is rotating perfectly true, about 1.5mm out. He believes will increase likeliness of throwing belts.
He's taken pulley off looking for debris and found none. Also some other checks.
He's going to do up an email and video and send to Bullet for their advise.
However, thought I'd come here in case anyone else has experienced/noticed this?
Thanks.
diss7 is offline   Reply With Quote
Old 08-29-2013, 10:01 PM   #1319
diss7
Thanks.
Copy of the email and video, for anyone following...
Hi Tom and Mike.
I just happened to give the SC a bit of a once over before starting the job and noticed that the Pulley is not running true on the input shaft.
- I checked that all pulley bolts were tight
Here is a link to a video on youtube showing the movement
After filming the video, I removed the 4 pulley bolts and inspected the mounting flange and the inside of the pulley for any debris etc that may be causing the run out. But I didnt find anything.
The pulley mount on the input shaft appears to be running true (this was inspected by eye as I dont have a DTI available) and a quick measure of the depth on the back of the pulley came up relatively even (once again this was only done using verniers) The internal mounting surface of the pulley appears to be true to the belt drive section, leading me to believe that the pulley is not bent. I would target my concerns to a possible high spot or mismachining of either the pulley internal surface or the mounting flange.
Cheers
Beau
Old 08-29-2013, 11:11 PM   #1320
phloozy
phloozy's Avatar
Drives: Scion FR-S
Question for those on e85/93, what do you do if you are on a road trip and the gas station only has 91?
phloozy is offline   Reply With Quote
Old 08-29-2013, 11:14 PM   #1321
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
https://play.google.com/store/apps/d....ethanol&hl=en
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 08-29-2013, 11:24 PM   #1322
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Either switch your map and don't get on the car WOT or buy flex fuel
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-29-2013, 11:35 PM   #1323
phloozy
phloozy's Avatar
Drives: Scion FR-S
I would have a 93 and e85 map... now 91 :/
Old 08-30-2013, 12:58 AM   #1324
evo4g63
evo4g63's Avatar
I had a few quick pulls with a buddies Mazdaspeed3 with bolt ons and 50/50 e85 mix. Pulled ahead by about a car by top of fourth. He was a bit surprised at what the little blower on stock pulley could do. All runs done in Mexico of course.
-2016 Subaru WRX
Old 08-30-2013, 09:09 AM   #1325
swift996
swift996's Avatar
70mm pulley? What's your peak psi? I saw a lot of 8.5psi on the track and one sample of 9.1psi (running E85).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-30-2013, 11:34 AM   #1326
phloozy
phloozy's Avatar
Drives: Scion FR-S
Headed to moto east!!
Old 08-30-2013, 11:43 AM   #1327
sw20kosh
Yes. After the header install my peak boost was 8.5 psi. After the pulley it jumped up to 11.5 psi.
Old 08-30-2013, 11:45 AM   #1328
sw20kosh
Good luck!!!!
Old 08-30-2013, 11:48 AM   #1329
sw20kosh
There are 4 map slots. I would ask Mike to do something like:
(Start with the gas you are going to use most of the time. I am assuming 93.)
1. 93
2. E50
3. E85
4. 91
or simply
1. 93
2. E85
3. 91
Old 08-30-2013, 12:56 PM   #1330
Frostyman
Drives: 2013 Raven FRS
Hi Tom and Mike.
Cheers
Beau
Well THAT'S not good...
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
