Old 11-03-2012, 09:38 PM   #1303
2forme
I think avo said they wont be available until january. That makes me wait until spring to order. If they were available now, I'd already have it on my car.
Old 11-04-2012, 12:19 AM   #1304
alexm86
Drives: White GTS Manual
Yep not available till January, and they are taking deposits now.
http://www.avoturboworld.com/avoshop...sit-p-190.html
alexm86 is offline   Reply With Quote
Old 11-04-2012, 12:54 AM   #1305
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by Bomb3r View Post
No.
AVO18/49 Turbocharger with 5-7psi actuator, compressor wheel size 49.2/56 exhaust wheel size 50.5/68, rated to 380 i think.
Certainly not a TD05 of any type!
Listen to the video he said TD05-18G.
I know you got the numbers from their website but that's what the AVO guy on the vid said.
subatoy is offline   Reply With Quote
Old 11-04-2012, 01:05 AM   #1306
SalM
Drives: 2013 Whiteout FR-S
Can we crank up the whp if we bump up the boost a little bit?
SalM is offline   Reply With Quote
Old 11-04-2012, 01:32 AM   #1307
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by subatoy View Post
did he say TD05 18g turbo?
Yes yes he did.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 11-04-2012, 01:48 AM   #1308
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I was curious about this as well. We have 94 octane up here, thought it might be able to handle a little more boost?
OjiGeorge is offline   Reply With Quote
Old 11-04-2012, 06:55 AM   #1309
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
when you search the wheel specs AVO are doing for the turbo on this one, you'll find that Kando Dynamic do the same setup in a few of their turbo's, some with T25 inlet/outlet like this one looks to use.
JP is offline   Reply With Quote
Old 11-04-2012, 08:13 AM   #1310
Klar
Drives: 2013 FR-S Whiteout
I'm still waiting to hear about the fact that the autos use that space on the passenger-side head for something else. If this means we can't use this system, that sucks. I wanted a UEL system and really like AVO.
Klar is offline   Reply With Quote
Old 11-04-2012, 12:40 PM   #1311
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
We are not limited to this boost level/power at all - future upgrades can ramp up the power tremendously. We are just focused on our stage 1 kit reliability first. Then we will start releasing stage packages for bigger power later on.
The car has already done 2400 miles on the turbo kit, the majority of that on 91 octane (which, yes, really, really sucks), and we've gotten it to a very nice point on that gas quality. Anybody with better gas will naturally get better performance.
automatics
Automatic tuning and testing will commence after we finish up this stage 1 tuning/testing on the manual. Keep in mind here, the Japanese Legacy with a similar setup comes mainly in automatic form, but doesn't have that air pump. We know the reason why, and will release details about the automatic kit setups later.
AVOturboworld is offline   Reply With Quote
Old 11-04-2012, 01:21 PM   #1312
subatoy
subatoy's Avatar
Drives: subatoy
AVO are you guys planning on running a dyno on 93 oct soon?
230whp is basically a 2012 WRX power so that's a lot for this little car.
I still think 250whp is the sweet spot!
Old 11-04-2012, 02:53 PM   #1313
SalM
automatics
Do you guys think we can make close to 350whp on E85 and all the other things, fuel pump injectors tuned catback intakes etc..?
Old 11-04-2012, 06:16 PM   #1314
JD86
Drives: 2013 Toyota 86 GT
Originally Posted by stevo_12v View Post
I am thinking of going the same two mods are you planning, ie AVO and Spec-L.
Which tuner are you going to use?
http://www.stechnic.com.au/
Those guys were recommended via AVO, which is fairly hard to go past. I also have had multiple recommendations for them when I was going to tune my Rex.
Originally Posted by Blue86 View Post
Any boys from OZ care to guess the cost of the inspection and emissions test?
I doubt it will be that expensive, maybe a few hundred. I'd imagine it won't be much, if any more expensive than a road worthyness inspection is.
JD86 is offline   Reply With Quote
Old 11-04-2012, 06:32 PM   #1315
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The turbo is rated for 380 but im not sure if thats wheel or crank. With e85 and support mods im sure you could reach that power number.
Tansey86 is offline   Reply With Quote
Old 11-04-2012, 07:18 PM   #1316
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
I doubt it will be that expensive, maybe a few hundred. I'd imagine it won't be much, if any more expensive than a road worthyness inspection is.[/QUOTE]
Wouldnt this need and engineers cert to be "legit" along with the emissions test?
Bomb3r is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
