#1289 | |
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1290 |
@KraftWerks In the directions there is an all-caps warning to make sure that the rev limiter is set below 7800 RPM to not void the warranty. Is this the limit for both the C30 and the C38?
#1291 | |
#1292 | ||
Drives: Kraftwerks BRZ
#1293 |
Well, my order is most likely going in tomorrow for the c30-94 kit so you can add me to the list.
@KraftWerks, are you guys packaging the cogged idler pullies standard now? I went ahead and requested them in my order, but I just wanted to double check. |
#1294 |
Drives: 2022 BRZ Limited
@KraftWerks, do you think that I can combine your oil cooler with my OEM oil cooler so that I can use the Forester XT OEM oil cooler as keeping the temps steady ( water to oil) and the KW kit for better cooling at track days?
also what kind of oil cooler will the kit include? mocal or setrab? The reason I am asking this is because I believe Perrin had some issues with Mocal units a while ago thanks in advance
#1295 | ||
Yes, kits are shipping with cogged idlers as a standard. Quote:
Our cooler is a 19 row stack plate cooler. |
#1296 | |
http://www.ft86club.com/forums/showthread.php?t=50427
#1297 |
Drives: 2013 BRZ Premium Dark Gray Metallic
What do you guys think of this, together with the @KraftWerks plate?
Overall Height (in):2.188 in. Overall Width (in):26.250 in. Overall Thickness (in):3.250 in. Cooler Construction:Heat sink Cooler Material:Aluminum Inlet Size:1/4 in. NPT Inlet Attachment:Female threads Outlet Size:1/4 in. NPT Outlet Attachment:Female threads Number of Cooling Rows:2 Cooler Finish: Natural |
#1298 |
Drives: A bunch of 'em...
I will combine my sandwich with a 16 row cooler.
#1299 |
Drives: Subaru BRZ-SWP
I have a problem when I tried to flash my ecu with ecutek it has an error saying that the file I have its not compatible with my dongle. Any suggestions?
Sent from my SGH-M919 using Tapatalk |
#1300 |
#1301 |
Thanks, I'll contact @KraftWerks @fteightysix tomorrow. I was hoping to have the car running today, oh well, shooting for tomorrow, the install was straight forward, only tricky part was the rotrex, oil bleeding process other than that I'm very happy the way it looks.
#1302 | |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
