Old 06-17-2016, 06:46 AM   #12923
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
I want a beer
The Twins make me smile
soulreapersteve is offline
Old 06-17-2016, 06:59 AM   #12924
I want a beer
Oh great, do we have to do another cyber intervention?
Tcoat is offline
Old 06-17-2016, 07:02 AM   #12925
soulreapersteve
I want something else cyber related....
Anyhoo, doesn't this sound familiar???
A Tesla is faster than many Porsches in a straight line. I doubt many (any?) Teslas are smoking Porsches at the track. The straight line performance is fun, no doubt, but only a committed drag race fan buys a Tesla because it "outperforms" a proper sports car.
Old 06-17-2016, 07:49 AM   #12926
Phijkchu
Phijkchu's Avatar
Drives: Feet
Missing stuff?
Some drama I was mildy interested in that ichi probably deleted for the greater good.
Phijkchu is offline
Old 06-17-2016, 08:24 AM   #12927
Ahhhhh. Just ask and one of will fill you in.
Tcoat is offline
Old 06-17-2016, 08:38 AM   #12928
Ashikabi
Ashikabi's Avatar
upload img
New project: "Cable tower". Looking for some info on what a part is called so I can find one online.
The pink line is the cable. When the handle is pulled, the "weight plate carrier" will travel upwards. The "carrier guide" will keep it from swinging or otherwise moving around. The guide will slide on a rod.
I want a bushing in the"carrier guide"(probably one on top and one bottom) so it's not metal on metal. What is the "bushing" called. Where can I find one? Did a Google search for "nylon bushing" but mainly turned up pvc fittings(which may work). What should I be searching for instead? ID should be 1 inch at least IMO.
Ideas? Thoughts? Design ideas? Let's hear it
(I don't know why the image is in landscape, its in portrait on my phone)
Ashikabi is offline
Old 06-17-2016, 08:42 AM   #12929
upload img
http://www.mcmaster.com/#nylon-sleeve-bearings/=12w4izu
Tcoat is offline
Old 06-17-2016, 08:53 AM   #12930
Ashikabi
Ashikabi's Avatar
I knew this was the right place to ask... so how do you retain them? They don't have a lip and I'd prefer not to have to turn a seat for them
Ashikabi is offline
Old 06-17-2016, 08:56 AM   #12931
Look in the upper left under "Narrow by" there are flanged options.
Tcoat is offline
Old 06-17-2016, 09:25 AM   #12932
Ashikabi
Ashikabi's Avatar
Alrighty, thanks
Ashikabi is offline
Old 06-17-2016, 09:29 AM   #12933
Alrighty, thanks
If you make your guide a clamp then you will be able to hold the bushings in just by friction. You could install some bolts through the guide to hold the bushings as well but that could be overkill if the clamp force is enough.
Tcoat is offline
Old 06-17-2016, 09:39 AM   #12934
Ashikabi
Ashikabi's Avatar
I thought about that but it would be a lot more work. I work in a tube steel shop so making things from tube is easy, anything flat is a pain cuz I have to draw and send it off to be cut. I suppose a clamp would allow replacement of the bushings without full disassembly though...
Ashikabi is offline
Old 06-17-2016, 09:44 AM   #12935
If working with a tube just go with two bolts (each) to secure a split flanged bushing top and bottom. To change the bushings you would just need to remove the bolts, slide them out of the tube, split them and remove them from the shaft. Doubt you would have to replace them often (if ever) though since they really shouldn't take much wear in a hand operated process.
Tcoat is offline
Old 06-17-2016, 09:46 AM   #12936
Ashikabi
Ashikabi's Avatar
How would the bolts secure the flange?
Ashikabi is offline
