#12923 |
Contract? /人◕ ‿‿ ◕人\
I want a beer
#12924 |
Oh great, do we have to do another cyber intervention?
#12925 | |
I want something else cyber related....
Anyhoo, doesn't this sound familiar??? ![]() Quote:
#12926 |
Drives: Feet
#12927 |
Ahhhhh. Just ask and one of will fill you in.
#12928 |
upload imgNew project: "Cable tower". Looking for some info on what a part is called so I can find one online. The pink line is the cable. When the handle is pulled, the "weight plate carrier" will travel upwards. The "carrier guide" will keep it from swinging or otherwise moving around. The guide will slide on a rod. I want a bushing in the"carrier guide"(probably one on top and one bottom) so it's not metal on metal. What is the "bushing" called. Where can I find one? Did a Google search for "nylon bushing" but mainly turned up pvc fittings(which may work). What should I be searching for instead? ID should be 1 inch at least IMO. Ideas? Thoughts? Design ideas? Let's hear it (I don't know why the image is in landscape, its in portrait on my phone) |
#12929 | |
#12930 | |
#12931 |
Look in the upper left under "Narrow by" there are flanged options.
#12932 |
#12933 |
If you make your guide a clamp then you will be able to hold the bushings in just by friction. You could install some bolts through the guide to hold the bushings as well but that could be overkill if the clamp force is enough.
#12934 |
I thought about that but it would be a lot more work. I work in a tube steel shop so making things from tube is easy, anything flat is a pain cuz I have to draw and send it off to be cut. I suppose a clamp would allow replacement of the bushings without full disassembly though...
#12935 | |
#12936 | |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
