Old 11-12-2014, 10:11 PM   #1275
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by kbogarto View Post
I purchased AVO stage 1 from Paul. I'll be installing it december 13th and having HRI tune it.
Would appreciate if you could take the time to document the install process with some pics, and then let us know of any issues or quirks you faced when fitting everything in.
The install manual makes it seem pretty straight forward, but I've been told it's far from that.
Fizz is offline   Reply With Quote
Old 11-12-2014, 11:32 PM   #1276
Astroboy
Astroboy's Avatar
Drives: None
What oil is everyone running? I recently changed to Motuls xclean 5w30 and all of the sudden the weather decides to change. The temperature here in the dfw is between 60f and 40f. When the temperature we in the lower 50s, my oil temp was around 20 in Celsius during start up. After about 10-15 minutes of driving, the oil temp finally got up to 90Celsius. Anyhow, is this normal?
Astroboy is offline   Reply With Quote
Old 11-13-2014, 04:26 AM   #1277
JD86
Drives: 2013 Toyota 86 GT
Originally Posted by Fizz View Post
I've been told that the "turbo-airbox silicone pipe" comes very close to the crank pulley. Has anyone had rubbing or contact in that area on their kit?
Yes, but not because of alignment or fitment of the pipe clashing with the pulley. I had a few issues with that pipe coming off the turbo. It was nothing a new pipe clamp and some cable ties couldn't fix. We also trimmed a little off the blow off valve outlet pipe as that was pushing the whole piece towards the airbox side of the engine bay and part of why the bottom kept coming off the turbo.
When it's fitting correctly though there's plenty of space and no need to change pulleys or bolts on the pulleys.
JD86 is offline   Reply With Quote
The Following User Says Thank You to JD86 For This Useful Post:
Fizz (11-13-2014)
Old 11-13-2014, 08:51 AM   #1278
GremlinGSP
Mine actually just got into the water pump pulley. Apparently It go loose when I did some work this weekend and then with my perrin intake pipe it was just pushed right over into it. Didn't go completely through but its still bad enough I'm sourcing a replacement. I wouldn't mind being able to upgrade to all metal piping. I've had that tube come off twice now. And I've upgraded to t-bolt clamps.
To me that's my biggest complaint with the turbo.
GremlinGSP is offline   Reply With Quote
Old 11-13-2014, 09:51 AM   #1279
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I reckon its because the turbo inlet is non-beaded....so I could see why they come off easily. Might need to look for some ultra strong hairspray
Old 11-13-2014, 11:11 AM   #1280
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I have never had my turbo inlet hose come off/lose
how much boost are you running to be having piping problems?
PS this is not directed at Fizz, as he is clearing talking about someone else is problems, I am just too lazy to find the original poster of this issue
The Following User Says Thank You to SkAsphalt For This Useful Post:
Fizz (11-13-2014)
Old 11-13-2014, 11:43 AM   #1281
kbogarto
Drives: 2013 BRZ limited WRB
Yea there will be three of us installing it so should have an extra hand to take some pictures. Most posts I've seen about the install say it's relatively straight forward.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
Fizz (11-13-2014)
Old 11-13-2014, 04:34 PM   #1282
thirst
Drives: Subaru BRZ
Sorry if this has been asked a million times, but does anybody have a break down of what all the bolts need torquing to for this kit??
thirst is offline   Reply With Quote
Old 11-13-2014, 06:27 PM   #1283
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Nobody knows as the manufacturer doesn't provide any for the kit. But stuff like manifold to engine flange nuts would just follow OEM values.
Old 11-13-2014, 07:09 PM   #1284
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
Old 11-14-2014, 03:36 AM   #1285
JD86
That pipe is pre-turbo so boost pressure shouldn't have anything to do with that pipe coming off... But for reference 16+ psi at the time of issues.
I've just wound up running a couple of cable ties around it to the turbo compressor outlet pipe to pull them towards each other and problem solved.
Old 11-14-2014, 04:11 AM   #1286
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Cable ties ftw!
The Following User Says Thank You to Fizz For This Useful Post:
@Art_Mighty (11-14-2014)
Old 11-14-2014, 11:56 AM   #1287
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I was chatting with a friend who works in an exhaust shop, and he suggested that I should lay a continuous tig-weld bead around the outer edge of the turbo compressor inlet. It should act like a rolled bead and allow the silicone hose to bite better.
Opinions? Bad idea?
Old 11-14-2014, 09:34 PM   #1288
Mechazawa
Drives: FR-S, 6MT, White
Opinions? Bad idea?
I have done it several times. Works great. The bead need not be continuous ether. I usually do three evenly spaced beads about 1 inch long each.
Mechazawa is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
