Old 06-13-2016, 03:40 PM   #12671
humfrz
All OEM brakes on all cars work equally well for stopping in your normal driving and there is no advantage given by bigger brakes. As has been said in many threads your tires will lose grip before you max out the ability of even OEM brakes. That is why anti lock was invented. In your scenario you would have stopped in exactly the same distance even on stock brakes. It is easy to say.
Now, if you had done 100 sudden stops and heated them up nicely before that emergency then ya the bigger brakes could have stopped you shorter. Not because they had more surface but because they could deal with the heat better.
Just to chime in here.........
I totally concur with @Tcoat (this time .... ).
I maintain that for most all highway driving (non track) in the US at least, that the OEM brakes on most cars are adequate to stop the car, even under the harshest down hill use (assuming you use gearing wisely).
For example I came down off of Pikes Peak (14,000 ft) in my old MX-5 (with OEM brakes) as fast as I could and still keep it on the road and when I was stopped at the mandatory brake check station, my brakes measured up real good (I didn't even have to pull over to allow them to cool down).
Now, I'm not saying that "big brakes" are not good for the track ...... just not beneficial for highway driving.
humfrz
humfrz is offline
Old 06-13-2016, 03:45 PM   #12672
humfrz
One supply sergeant tried to tell us the 1961 stamped on the box was a stock number.
Would that be the same supply sergeant that told you that those boots are the right size ....... (they'll beak in ......).
humfrz
humfrz is offline
Tcoat (06-13-2016), Ultramaroon (06-13-2016)
Old 06-13-2016, 03:45 PM   #12673
humfrz
You mean you don't usually?
Tcoat is offline
humfrz (06-13-2016)
Old 06-13-2016, 03:52 PM   #12674
p1l0t
p1l0t's Avatar
Except I didn't have stock tires or wheels. I think you missed that part. Otherwise trucks would have miata pads...
p1l0t is offline
Old 06-13-2016, 03:54 PM   #12675
humfrz
Sort of like the old story about the 8 old boy, who never had spoken a word, was sitting at the breakfast table, when he exclaimed "THIS TOAST IS BURNT".
His parents were astonished and said out, Johnny, you CAN talk, why haven't you ever said anything .... ??
He replied ...... everything was OK up until this point ........
( ....... is it ma nap time, yet ...... ??)
humfrz
humfrz is offline
Old 06-13-2016, 03:57 PM   #12676
humfrz
Now, that wouldn't be OEM, now would it ....??
humfrz
humfrz is offline
p1l0t (06-13-2016)
Old 06-13-2016, 04:08 PM   #12677
Ya I was already typing when you said you had 18" wheels (irrelevant to braking power) and wider tires. Even then does not mean you would not have stopped in the same distance since you still would not have overpowered the stock system with a wider tire.
Your truck comment is just silly since of course they are bigger. They are bigger OEM systems.
I know you may not know where I work but take my word for it that debating brakes and/or airbag systems with me would be like me telling you how to fly a plane. I don't care what the internet theories are about bigger aftermarket brakes and day to day driving I have the facts at hand every day.
Tcoat is offline
jawn (06-13-2016)
Old 06-13-2016, 04:12 PM   #12678
p1l0t
p1l0t's Avatar
So why do you think that a wider footprint on the road or larger brakes/rotors can't stop in less distance? I'm very interested to hear your theory on how how are brakes are created equal.
p1l0t is offline
Old 06-13-2016, 04:23 PM   #12679
I didn't say a larger foot print would not stop you shorter I said a larger footprint with OEM brakes will stop you in the same distance as with larger brakes.
Again, the OEM brakes are designed to hold longer than the tires will hold grip. Having anything bigger gives no advantage until heat becomes involved. End of story.
There is a huge advantage to having bigger brakes in a racing situation but that does not transfer over to regular driving.
Tcoat is offline
Old 06-13-2016, 04:25 PM   #12680
Ashikabi
Ashikabi's Avatar
Now I'm no professional but I kinda gotta go with P1lot here. Just because the stock system wouldn't be over powered doesn't mean larger brakes couldn't reduce your momentum faster assuming the tires weren't over powered
I man bigger brake calipers, not necessarily rotors
ALSO bbks should come with"better"than stock brake pads
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
p1l0t (06-13-2016)
Old 06-13-2016, 04:29 PM   #12681
p1l0t
p1l0t's Avatar
Ok so you were completely lost because I had 18" and wider tires with a much larger footprint AND Brembos. The braking performance was AWESOME compared to stock.
p1l0t is offline
Old 06-13-2016, 04:37 PM   #12682
How do 18" tires make give you more surface area? Presuming still at stock outside diameter of course.
Not "lost" at anything and thought I was very clear.
Tcoat is offline
Old 06-13-2016, 04:43 PM   #12683
How are the pads "better" if the stock ones have not surpassed their abilities?
You guys think that the OEM system just barely stops the car? There is a huge safety factor engineered in there.
Tcoat is offline
jawn (06-13-2016)
Old 06-13-2016, 04:44 PM   #12684
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Your master cylinder is only so large. You do have better brake feel with a lot of big brake kits, but assuming the same tires, your 60-0 brake distances aren't significantly affected.
jawn is offline
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (06-13-2016)
