#12671 | |
![]() I totally concur with @Tcoat (this time .... ).I maintain that for most all highway driving (non track) in the US at least, that the OEM brakes on most cars are adequate to stop the car, even under the harshest down hill use (assuming you use gearing wisely). For example I came down off of Pikes Peak (14,000 ft) in my old MX-5 (with OEM brakes) as fast as I could and still keep it on the road and when I was stopped at the mandatory brake check station, my brakes measured up real good (I didn't even have to pull over to allow them to cool down). Now, I'm not saying that "big brakes" are not good for the track ...... just not beneficial for highway driving. humfrz |
#12672 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (06-13-2016), Ultramaroon (06-13-2016) |
#12673 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (06-13-2016) |
#12674 | |
Sent from my SM-G920P using Tapatalk |
#12675 |
Sort of like the old story about the 8 old boy, who never had spoken a word, was sitting at the breakfast table, when he exclaimed "THIS TOAST IS BURNT".
His parents were astonished and said out, Johnny, you CAN talk, why haven't you ever said anything .... ?? He replied ...... everything was OK up until this point ........ ![]() ( ....... is it ma nap time, yet ...... ??)humfrz |
#12677 | |
Your truck comment is just silly since of course they are bigger. They are bigger OEM systems. I know you may not know where I work but take my word for it that debating brakes and/or airbag systems with me would be like me telling you how to fly a plane. I don't care what the internet theories are about bigger aftermarket brakes and day to day driving I have the facts at hand every day.
| The Following User Says Thank You to Tcoat For This Useful Post: | jawn (06-13-2016) |
#12678 | |
#12679 | |
Again, the OEM brakes are designed to hold longer than the tires will hold grip. Having anything bigger gives no advantage until heat becomes involved. End of story. There is a huge advantage to having bigger brakes in a racing situation but that does not transfer over to regular driving.
#12680 |
Now I'm no professional but I kinda gotta go with P1lot here. Just because the stock system wouldn't be over powered doesn't mean larger brakes couldn't reduce your momentum faster assuming the tires weren't over powered
I man bigger brake calipers, not necessarily rotors ALSO bbks should come with"better"than stock brake pads |
| The Following User Says Thank You to Ashikabi For This Useful Post: | p1l0t (06-13-2016) |
#12681 | |
#12682 | |
Not "lost" at anything and thought I was very clear.
#12683 | |
You guys think that the OEM system just barely stops the car? There is a huge safety factor engineered in there.
#12684 |
Drives: 2015 CWP BRZ Limited
Your master cylinder is only so large. You do have better brake feel with a lot of big brake kits, but assuming the same tires, your 60-0 brake distances aren't significantly affected.
| The Following User Says Thank You to jawn For This Useful Post: | Tcoat (06-13-2016) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
