#113 | |
Drives: Scion FRS
If the TOB is not returning to its withdrawn position or of there is some contact whatsoever then the TOB is being spun all the time. This means the TOB is used all the time and maybe why so many premature failures and rattle at idle. When I adjusted my clutch I made sure the master cylinder plunger is fully back sitting at its base and made sure the clutch switch position is not preventing the master plunger from fully retracting. If it was preventing the plunger from fully retracting it could be pushing the slave cylinder plunger ever so slightly that the TOB might be rubbing against the clutch spring but not exerting pressure. If this rubbing continues the TOB can fail. Those with failed TOBs can you make sure the main plunger at the footwell is all the way back when you release the clutch and that the switch is not preventing it from retracting fully? |
#114 | |
not playing cards
But by design, the TOB rests against the clutch fingers. No-load rotation is ok.
#115 |
Drives: 86
WTF
. Time for a monster OSG BRZ / 86 clutch upgrade...
#116 |
Since I have not had the car on a lift, is there a small removable inspection plate on the bottom of the bell housing?
#117 | |
#118 | |
Drives: Scion FRS
I simply cannot imagine this to be a bearing defect since most bearings undergo rigorous tests and some failures happen with as low as 30K miles. It is possible there is some condition that is accelerating the failure and the only one I can think of is no-load rotation of the bearing or occasional no-load rotation of the bearing. Not sure but just putting it out there. |
#119 |
Drives: Scion FRS
If we can prove it though then Toyota and Subaru cannot deny warranty claims anymore and I can see a recall coming of some sort.
#120 |
Drives: FR-S Whiteout
Well they've already denied my warranty claim, so I'm going to adjust the shit out of it.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | riironman (11-26-2015) |
#121 |
Drives: Scion FRS
Lol! Don't do that haha... Just adjust it so that you fully disengage the the clutch and still have half an inch or so to go towards the firewall so you know for sure the clutch isnt dragging. Also make sure that when you adjust the clutch switch it is not preventing the full return of the system. Or rather make sure the metal plunger hits its base and you have 1mm gap at the clutch switch so the system is fully retracted when not in use.
| The Following User Says Thank You to thambu19 For This Useful Post: | solidONE (11-19-2015) |
#122 |
Drives: Nevermorange FRS
Whoa.. I'm gonna join the party here.
Every so often my TOB would "honk" when I depressed it shift but now it's escalated. When the car is cold, like getting firing up in the morning or after work, the TOB is very audible when the clutch is depressed. So much so that this morning I almost considered driving the Expedition to work. However, once the engine/transmission is warmed up the TOB doesn't make the grinding noise when the clutch is depressed so it would be very hard to take it to the dealer and replicate it in front of them. I'd have to drop it off and come back. I'm going to call the dealer tomorrow and see what they say.
PRO86 | WTCC | STL
#123 | |
Drives: 2014 WRB BRZ
this 100% i have taken it to 2 subaru dealerships and they cant replicate it because its not severe enough as it when i first start up the car. |
#124 | |
Drives: Scion FRS
I am wondering if they used the wrong grease for the bearing that gets too thick at colder conditions and is fine at normal working conditions. On the other hand I am suspecting the actuation mechanism itself. Is there a spring the the clutch fork, bearing assemble meant to being the bearing back to its base position and clear the clutch pressure plate when clutch is released? I have seen many models that has a return spring. Not sure if we have such a spring. If we had one the bearing should be well clear of the clutch pressure plate when no force is applied on the clutch pedal and nothing should squeak. |
#125 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (11-19-2015) |
#126 | |
not playing cards
![]() Again, there are two issues at play, the creak from moving the TOB, or a failed TOB. I have the creak.
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 03:17 AM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
| Release Bearing or Pilot Bearing | Cal3000 | Engine, Exhaust, Transmission | 11 | 01-27-2015 11:39 PM |
| Friday Ruined... | mbh1101 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 07-20-2013 02:58 PM |
| How do you know that your day is already ruined? | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-03-2012 10:58 AM |
