Old 06-20-2015, 02:09 PM   #113
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Last update, I'm in about 3k with the kit and the turbo oil return gasket was slightly damaged by the oil and heat. I think it'll be a good idea to stock a few of these. Got some gasket paper and made a double one. Should be good for now.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-20-2015, 04:41 PM   #114
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Can you get a picture of said gasket for the records?
Rybot is offline   Reply With Quote
Old 06-20-2015, 04:45 PM   #115
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
I bought like 5 more of them. Its the gasket that is on the bottom of the turbo. It happens to a lot of turbos.
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 06-20-2015, 05:07 PM   #116
Rybot
Rybot's Avatar
Did you start losing boost or something? How were you able to tell?
Old 06-20-2015, 05:11 PM   #117
drambo136
drambo136's Avatar
Noooo its the oil drain at the bottom of the center section. Ull get an oil leak if it gets bad
The Following 2 Users Say Thank You to drambo136 For This Useful Post:
Rybot (06-21-2015), yomny (06-20-2015)
Old 06-20-2015, 09:37 PM   #118
Rybot
Rybot's Avatar
Ah, that makes more sense. Sorry for the misunderstanding.
Old 06-20-2015, 09:38 PM   #119
drambo136
drambo136's Avatar
No prob buddy. I'm just glad I can help. This kit should come stock on the car lol
Old 06-20-2015, 10:11 PM   #120
yomny
yomny's Avatar
Thats a fact lol.. the kit is great and all turbo drain gaskets seem to be the same vulnerable material, like a thick piece of paper.. its only a matter of time before they give. Its like changing your air filter, its one of those things that should be done regularly. I noticed because i look at my engine bay almost after every drive and saw a little splash on the bottom engine under tray, immediately noticed the source. Maintenance is the key, just like with any car, turbo or non.. things will eventually leak or crack, break.. not often but we have to be ready and on top of it.. Its the cost of powa!! lol aside from money lol.
Old 06-20-2015, 10:12 PM   #121
yomny
yomny's Avatar
Very small, about 2"x1" if i had to guess.
The Following User Says Thank You to yomny For This Useful Post:
Rybot (06-21-2015)
Old 06-21-2015, 03:22 AM   #122
Rybot
Rybot's Avatar
I'll agree on the maintenance thing. Goes with any system. Hoping it'll be a least semi-reliable without a load of repairs.
Old 06-21-2015, 03:24 AM   #123
Rybot
Rybot's Avatar
Ah, thank you. Those look extremely cheap.
Old 06-21-2015, 10:19 AM   #124
yomny
yomny's Avatar
And what's worse is that they're all like these, no matter what company makes it. I just stacked two and keep spares around. It shouldn't need replacement that frequent though.
Old 06-21-2015, 10:22 AM   #125
yomny
yomny's Avatar
I can't complaint honestly about the kits quality. I haven't had it for long but everything fits like oem, clearance is good on all parts and they look like they'll be there for long. Nothing seems outta pace or as if it were force fit. Get on the bus and join the group
drambo136 (06-21-2015)
Old 06-21-2015, 12:46 PM   #126
yomny
yomny's Avatar
Update: the gasket for the drain is looking moist, meaning oil is finding its way out and it's a matter of time before it drips. This is frustrating, maybe I'm too anal and these things are never supposed to be completely dry but I do recall it being dry prior to now. I think the fact that the center section oil outlet is square and all the flanges for the drain hoses are round allows for oil to get to the gasket. That or the flange isn't sealing well enough. Regardless I don't want to leave things this uncertain and ordered a drain flange with a square inlet and O ring.
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Powerhouse Amuse Single Exit Exhaust + R1000 FP Review BrianJC Engine, Exhaust, Transmission 26 06-06-2016 10:09 PM
My OEM Audio Plus 400 Install and Review Yruyur Electronics | Audio | NAV | Infotainment 156 03-01-2016 05:53 PM
TRD Sharkfin Install and review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 27 07-19-2014 07:21 PM
REVIEW: Berk Technology Single Exit Track Pipe w/ Tip NYC BRZ Engine, Exhaust, Transmission 11 12-29-2012 08:22 PM
