Old 10-16-2014, 09:14 AM   #113
diirk
diirk's Avatar
Drives: 4Runner
Originally Posted by Jyn View Post
Is that for bags or for tanks? I normally lose ~20 PSI in my tank overnight.
Reading through the instructions again, AirRide doesn't seem to differentiate between tank or bag leaks. They just say that typical loss is 2-4 PSI over a 24 hour span of time. Anything over 5psi in 24 hours needs to be corrected.
When I went through fixing leaks the last time, I used the liquid PTFE sealant and it seemed to work better than the tape. I was also meticulous in torquing the fittings.
Another important point is that once you have a fitting torqued, leave it alone. If you retorque it, you will break the seal. You need to remove, clean, reapply your sealant and reinstall.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-16-2014, 09:37 AM   #114
diirk
diirk's Avatar
Drives: 4Runner
Originally Posted by _frs View Post
Has anyone heard of d2 air suspension? Debating between d2 and airlift, because d2 comes with a trunk mounting board and airlift doesn't, as well as being several hundred dollars more expensive.
any adivce?
I've never heard of them, so I looked it up.
For the small difference in price, you're giving up a really nice digital controller for a manual controller with a single guage. And, an unknown mfg for the struts, whereas the AirLift struts are made by BC Racing.
It's your call obviously, but I'd recommend AirLift or AirRex.
diirk
Old 11-19-2014, 12:49 PM   #115
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Bumping this thread back to life.
Here's a recent customer freshly bagged on an Airlift V2 System!
Chaz@ORT is offline   Reply With Quote
The Following User Says Thank You to Chaz@ORT For This Useful Post:
diirk (11-19-2014)
Old 11-19-2014, 01:03 PM   #116
diirk
diirk's Avatar
Drives: 4Runner
Maybe be looking for a setup to fit a 2015 S5....
diirk
Old 11-19-2014, 01:59 PM   #117
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Maybe you should shoot me an email and we can hook it up ;]
diirk (11-19-2014)
Old 11-19-2014, 02:12 PM   #118
Andrew@ORT
Drives: BT 6.4 (tow pig) / e46 M3
any adivce?
We've never sold a D2 product, but I've had friends who have ridden in D2 equipped and it's not a bad setup. From what I'm told, it rides a bit rough compared to the Air Lift products.
Originally Posted by AtlasMick View Post
I have a general question about bag systems, but it might depend on the bag manufacturer.
They designed these kits for our cars with about stock weight of tire/wheel in mind (I'm assuming). Comparing coil-overs to bags, does anyone know how the physics work for say, adding weight to the tire/wheel combo by having a much larger wheel/tire like some of the widebody people are doing?
Is the effect noticeable or negligible going from stock weight to something heavier like a 10-11" wide wheel and does this affect how much pressure(bags) or spring/damper (coils) you would need?
I'm not quite sure what you're saying with regard to spring rates with wider or bigger wheels. From what I'm gathering, you're asking if an air suspension setup can be adjusted to accommodate for additional weight / load / aka bigger wheels? The short answer is yes. But in order for me to give you the most accurate response, I'll need some clarification on your point.
I'm definitely interested in answering your question, shoot me an email or call if you'd like!
What this guy said!
Loctite 565 or PTFE sealant works best on the fittings.
Andrew@ORT is offline   Reply With Quote
The Following User Says Thank You to Andrew@ORT For This Useful Post:
diirk (11-19-2014)
Old 11-20-2014, 06:09 AM   #119
AtlasMick
Drives: FR-S 2013 Asphalt
Let's say you have a system dialed in with a 8" wide wheel 235 width tire that is pretty close to the stock wheel/tire weight with a 1-1.5" drop like a lot of people are doing.
Then, you have the same coilover system being used by someone running a 11" wide wheel and 275 width tire on the same drop.
How or would you even need to adjust the bag system to account for the extra weight?
AtlasMick is offline   Reply With Quote
Old 11-20-2014, 08:09 AM   #120
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Nope.
Old 11-20-2014, 10:33 AM   #121
Andrew@ORT
Nope.
the short answer is: no.
the long answer is: with different wheel and tire combinations, you should take the proper precautions to make sure you have enough clearance between the wheel and the bag. the beauty of the air lift performance system is that you can make multiple adjustments to the strut in order to make room for wide wheels.
Old 11-28-2014, 01:19 PM   #122
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Anyone taking advantage of black friday deals to get their frs/brz to kiss the pavement?!
Old 11-30-2014, 01:54 PM   #123
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Old 12-05-2014, 11:10 PM   #124
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Would there be any interest if we ran another Group Buy for Airlift V2 Kits?
JDsThatGuy (09-04-2015)
Old 12-13-2014, 06:47 PM   #125
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
Old 12-13-2014, 06:59 PM   #126
Calum
That Guy
Drives: 2013 asphalt FRS MT
All I can think of when seeing those is:
The Following User Says Thank You to Calum For This Useful Post:
cdrazic93 (06-25-2015)
Track Brake Pad Discussion Thread CSG David Tracking / Autocross / HPDE / Drifting 422 04-03-2025 10:13 PM
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Brake Pad Discussion Thread CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 06-26-2014 05:59 PM
Another Coilover discussion thread... nobody__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-04-2014 10:49 AM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
