Old 05-27-2014, 12:51 AM   #113
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by TmP View Post
Tracked my BRZ yesterday for the first time and was shocked!
My SG2 went as high as 275 degrees oil temp!!! On a bone stock car.
Where is the factory oil temp sensor located?
What do you guys consider a safe temp range?
I have a blower sitting at home for the car, but I am scared to put it on, as the car runs wicked hot stock. Don't even want to know what it's going to run once boosted
It's going to run the same numbers. It just gets there faster with FI.
Tye300 is offline   Reply With Quote
Old 05-27-2014, 09:27 AM   #114
TmP
TmP's Avatar
Drives: A bunch of 'em...
Are you sure?
TmP is offline   Reply With Quote
Old 05-27-2014, 01:04 PM   #115
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Are you sure?
Yes. On the first page I posted a link to a website that tested more than a dozen oils at higher temps for an hour, check that site out. It's got some useful info for those looking to track their car.
Old 05-27-2014, 01:23 PM   #116
Dezoris
Dezoris's Avatar
Always going to have some adverse opinions on the forum.
Some of us have been collecting data for well over a year now.
195F - 220F is common within 10 minutes of spirited driving and is completely normal on a stock car.
Any Toyota/Subaru Engineer would have tested and experienced this during development.
Ranges and Data Collected:
100-169F Warm Up Phase, high oil pressures
170-189F Near Operating temps, oil pressures still higher
190-225F Normal Operating Range, oil pressures normalize
225-245F Middle End of operating range for track use, 5% drop in oil pressures
245-255F Upper End of operating ranges for track use, 10% further drop in pressures on 0w20
255-265F Red Zone of operating ranges for track zone, 0w20 starts to thin, oil pressures drop to questionable range.
265F+ Playing with fire on 0w20
The Following 5 Users Say Thank You to Dezoris For This Useful Post:
BRZPDX (05-28-2014), buddy32 (05-27-2014), CSG Mike (05-27-2014), jcz (10-25-2015), tahdizzle (08-03-2015)
Old 05-27-2014, 01:29 PM   #117
xwd
The factory sensor is below the oil filter next to the oil pressure switch.
Generally 250 is a little on the high side but many cars run right around there on the track. Above 260 and you definitely want to look at cooling things a bit more. What kind of oil were you running?
Old 05-27-2014, 02:49 PM   #118
TmP
TmP's Avatar
One week old car all stock as off the showroom floor including tire pressure. LOL
Except for a track pipe - muffler delete.
Old 05-27-2014, 04:02 PM   #119
Tye300
Tye300's Avatar
Are you sure?
Yes. I tracked my car a lot while NA. I had to pull into the pits after 5-6 hot laps when the oil temp starts to get around 130-135C. After my SC install, without the oil cooler, I would reach the same temps in 3 hot laps.
Old 05-27-2014, 04:09 PM   #120
TmP
TmP's Avatar
So I need an oil cooler. I plan on running more than 3 fucking laps...
Old 05-27-2014, 04:26 PM   #121
Tye300
Tye300's Avatar
It would do your engine a great benefit if you do so.
Old 05-27-2014, 04:28 PM   #122
TmP
TmP's Avatar
On it.
Problem is, there seem to be none that fit the KW blower kit...
Old 05-27-2014, 05:53 PM   #123
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
On it.
Yeah we need something for this kit. @KraftWerks are you guys planning to release a oil cooler kit for the SC kit?
zoth is offline   Reply With Quote
Old 05-27-2014, 06:31 PM   #124
CSG David
CSG David's Avatar
You might want to call them up to see where they're at in their production phase.
Old 05-27-2014, 06:33 PM   #125
FR-S Matt
About to pull the trigger on the Kraftwerks kit.
Oil cooler necessary for on the street and daily driving or will I be able to get by without? I figure I won't push it to extreme levels like a track would for starters, but it's also not really cool during summers here. Plan on getting the Kraftwerks oil cooler when it releases for that piece of mind regardless of daily driving.
Old 05-27-2014, 06:39 PM   #126
CSG David
CSG David's Avatar
You don't need an oil cooler if you don't drive the car.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
FR-S Matt (05-27-2014), Wayno (08-31-2015)
Oil cooler needed? Don't know? See some results inside Sportsguy83 Engine, Exhaust, Transmission 159 03-15-2015 05:27 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Car/Ambient temperature to log data gdrider77 Software Tuning 6 01-19-2014 08:49 AM
