Old 08-19-2015, 12:52 PM   #113
motrsprt9150
Boss
Drives: asdf
Originally Posted by axelo View Post
How did you take it to the shop?? What did you use to seal temporary the hole of the stripped thread? I cant get my car in a tow truck in my apt building...i need to take the car to the street because parking lot is very uncomfortable.
Thanks god i'm getting late payments from my work this coming week.
Thanks!!!
I drove it there. I didn't do anything. I left the hole unplugged.
motrsprt9150 is offline   Reply With Quote
Old 08-19-2015, 09:34 PM   #114
axelo
Drives: Whiteout frs
Mtec people recommended me to use tape...and thats what i did, the shop didn't have to take the trans off...i was kinda hoping them doing it since I'm out of warranty and have the bad throwout? bad fork ?= crunch and noise at the end of depression of clutch....there's various threads about that... So that'll be in another not so far occasion. My shop is the best! Luck i guess!
Thanks for your answer!!! Happy
axelo is offline   Reply With Quote
Old 03-30-2016, 05:23 PM   #115
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
So I did the install of the shift spring over the weekend and just wanted to confirm that the feeling is correct.
it goes it gears quite smooth and quickly now, but i find pulling it out of gear is probably double the effort then before the springs. Is that how the shifter should now feel?
I'm only concerned since i didn't have a torque wrench that would fit up there, so i just tightened both bolts until they wouldn't budge. Is there a chance i may have over tightened and now bolts are compressing the springs to much?
jimmillion is offline   Reply With Quote
Old 03-30-2016, 06:18 PM   #116
15limited
15limited's Avatar
it goes it gears quite smooth and quickly now, but i find putting it out of gear is probably double the effort then before the springs. Is that how the shifter should now feel?
I felt the same difference, paired with a short shifter giving less leverage, gear changes need to be much more direct. My torque wrench is also too big...😂
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-30-2016, 09:42 PM   #117
gramicci101
Off Topic
The only thing the shift springs do is give the shifter a stronger return to center. To get a torque wrench on it you need to get creative with extensions and u-joints.
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 09:36 AM
DIY Trans Bushing, Rear Shift Bush, MTEC spring Q Ralph Spoilsport Engine, Exhaust, Transmission 7 10-31-2013 09:15 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 12:39 PM
