Old 11-21-2013, 08:30 AM   #113
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by solidONE View Post
I would think material that thin (the runners) will have problems with heat stress from the turbo. Why did you not opt to use thicker piping such as a Schedule 10 or thicker piping over thinner tubing?
I went with the thinner tubing because I have planned on running the support bracket. Also I just really enjoy working with the 065, if it cracks I can fix it. If it fails it's just an excuse to build another. The shape of these manifold is pretty unconventional being so long, so why not take a different approach.
And now that I think of it I've made EJ up pipes from 065 and never had an issue. If I could bump up the thickness a bit I would, maybe 081. But 065 material is the standard so lots of bends/shapes are available. I also considered using 316 stainless but I could find all the parts so I kept it 304.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
solidONE (11-22-2013)
Old 11-21-2013, 12:59 PM   #114
mrk1
Support bracket just about done, it would be sweet to have this milled from one piece of aluminum.
The Build Thread
Old 11-21-2013, 01:25 PM   #115
MAPerformance
Drives: Asphalt FRS
We could probably mill one out of a single piece of aluminum for you if you like. PM me if you are interested. Nice idea on the bracket!
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
mrk1 (11-21-2013)
Old 11-21-2013, 02:13 PM   #116
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Originally Posted by DIM View Post
P.S.
I'd be interested in buying a rear brace.
I, too, would be.
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
TheBatman (01-09-2014)
Old 11-21-2013, 03:26 PM   #117
mrk1
Local stealer did have a pan so I picked that up to start the oil drain
The Build Thread
Old 11-22-2013, 12:28 AM   #118
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Sir... You most definitely fabrication.
Intent > Content
Old 11-22-2013, 08:44 AM   #119
mrk1
Yup, I'm already planning my next manifold, twin scroll. Also talking to my bending guy about 321 stainless.
If this manifold cracks I look at it as a learning experience. If you never have failures your not pushing yourself enough.
The Build Thread
Old 11-22-2013, 09:17 AM   #120
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Truth.
Great work man!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
mrk1 (11-22-2013)
Old 11-22-2013, 03:39 PM   #121
mrk1
This 5 bolt housing is really pissing me off
The Build Thread
Old 11-23-2013, 03:07 AM   #122
350zgoingFRS_lol
BIG Dreamer =D
keep it up!! great job it'll b 9months before i get my own 86..so ill b studying your build for sure,along with the rest on here
350zgoingFRS_lol is offline   Reply With Quote
Old 11-25-2013, 05:37 PM   #123
mrk1
Mocked up the intercooler piping today, I dont think I have seen anyone else do this routing.
Im doing a comparison experiment with this car, Stainless vs Aluminum intercooler piping. This is the stainless version. Pictured its the cool side piping with the 2.5 to 3" transition and a bead rolled on the end.
The Build Thread
TRD_07 (11-26-2013)
Old 11-25-2013, 06:59 PM   #124
quiet-k
quiet-k's Avatar
Drives: 2014 Hot Lava FR-S
What exactly are you comparing? Power gain? What's your hypothesis, and why the comparison?
Keep up the wonderful fab work!
quiet-k is offline   Reply With Quote
Old 11-25-2013, 07:38 PM   #125
mrk1
Mostly temperature, technically thats power but I don't think it will be an amazing difference. The idea is just to see if SS will help is isolate heat from the engine bay, since the upper pipe is so close to the turbo. So really the experiment is more to do with just that upper pipe. These pipes will be powder coated and the upper will get some heat foil. SS also is nice because it wont crush under quality clamps, crushing an AL pipe is very easy with a T-Bolt.
The Build Thread
Old 11-26-2013, 04:14 PM   #126
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
It's coming along very nicely!
TRD_07 is offline   Reply With Quote
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 08:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 12:53 PM
