#113 |
Drives: Toyota GT86 6M/T
Hi guys,
Got my OFT a couple of weeks ago but just made the first log today. The car is running smoothly, so I'm not looking for any faults. Just trying to learn what all these figures show. Would you look at my log and tell me, if everything is as it should be? My car is almost stock, only mod is a HKS dropin filter. I'm planning on a FT86SF UEL header next year, but right now only running stage 1. I'm always on Shell V-Power, which is 99 RON in my country, and the only fuel with a minimum of 98 RON as stated in the manual. I must say the car is running so much better after the stage 1 file has been flashed! http://www.datazap.me/u/cawith/ots-s...7-8-9-10-11-12 One more question: In OFM my car's CAL is ***A00G, but the files loaded are A01G. How come? Those are the files which came with the OFT, and was no problem flashing it...? |
#114 | |
Drives: subaru brz-limited
http://datazap.me/u/zeppy/91oct-stg1...a=1-9-12-13-14
#115 |
Drives: 2014 Subaru BRZ
I have two third gear pull logs. Both have knock correction at low rpm. Thoughts?
http://www.datazap.me/u/hungrr/3rd-g...ata=5-28-33-39 http://www.datazap.me/u/hungrr/3rd-g...ata=5-28-33-39 93 octane Fbm basekit |
#116 | |
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#117 |
Drives: 2016 FR-S
Did my first data log with OFT just to see what it's like. This is using the 93oct tune. The car is stock with K&N filter. Just waiting to run the 93 out so I can fill with e85. The log is kind of long with random driving and a couple 2nd and 3rd pulls. I somewhat understand what I'm looking at here. Would you add or remove any of the things it's logging?
http://www.datazap.me/u/jmoody/first...g?log=0&data=1 |
#118 | |
#119 |
Poor College Kid
Drives: ~.~
I'm sorry if I missed it but is there a link or something to show ranges that your car should have on the data logs?
#120 | |
I have already read the thread with all the tips in it, was just not sure if I'd understood it correctly. Still trying to figure all this technical stuff out, that the OFT can show.
#121 |
#122 |
#123 |
#124 |
Drives: brz
Can you guys please look at this log for me. This is my first log with the oft. I am running the stage 1 map. I just put on the grimspeed intake and logged it to see what it looks like. The beginning of the log is a third gear pull and then driving on the highway running from third into 6th and back down again a couple times. I am trying to learn how to tune this with the oft. Please tell me if I am interpreting this correctly. Am I correct in thinking the car pulled timing @ 1.38. This is the first time kc learned value changed and the ignition advance drops. I am a little confused though because i thought the iam would drop once the car has seen knock from what I read on this forum. Then at 45.92 the kc learned starts to rise and the knock correction numbers start going negative but the iam doesn't change. Are both of these events knock? I have read a bunch of the tuning threads on this forum I just want to make sure I am looking at things correctly. Any suggestions would be greatly appreciated. http://www.datazap.me/u/underpowered...0&data=0-1-4-6
#125 | |
What's in the log itself looks okay, but you need to add some things to it for a fuller picture. put knock correction, LTFT, AFR, and Commanded AFR on there.
#126 |
Drives: brz
Thanks for taking a look at the first log Phrosty. This is the second log with the parameters you asked for. http://www.datazap.me/u/underpowered...o=2&zoom=3-167
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
