Old 09-26-2013, 08:00 PM   #113
wes1202
Drives: 86
can you use your stock front rotors for the subaru wrx calipers?
wes1202 is offline   Reply With Quote
Old 09-28-2013, 07:23 PM   #114
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
yes... its the same Dimension Rotor..offset and all . the stockers just have more Vain in them makeing them heavier.
Bill
Scooby South is offline   Reply With Quote
Old 09-28-2013, 08:20 PM   #115
wes1202
Drives: 86
Bill
thanks bill
Old 11-07-2013, 05:28 PM   #116
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Anyone install the black calipers yet?
Kostamojen is offline   Reply With Quote
Old 11-09-2013, 03:35 PM   #117
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yep, I've had the Black Calipers on for almost a year now.
Beyer Subaru is offline   Reply With Quote
Old 11-09-2013, 04:27 PM   #118
Kostamojen
Black rears too?
Old 11-09-2013, 04:32 PM   #119
Beyer Subaru
Nope. No real reason to. The backs are LGT. Seems more trouble than it's worth.
Old 06-02-2014, 04:36 PM   #120
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
Question TFTD
Alright, so I've necro'ed this thread for a reason. I was sort of intrigued with using the Subaru 4 / 2 pots as sort of a "poor mans bbk" since the STI brembos are only reasonable to buy used, and actual bbk's are a lot of money that I can't really justify given my current driving habits. I realize that buying the brembos used isn't such a big deal, and I could rebuild them myself, but I really like *new*. And the 4 / 2 pot set can be found for ~$1000-1100 new.
After doing some poking around, I found a kit by Godspeed that adapts the 4 pot fronts to use a larger, 335x32 mm rotor which is slightly larger than STI / Wilwood / AP racing.
Now, this kit does make the price more in league with some of the other options, but I was wondering if anyone had any experience with something like this or knew of alternatives. I would try to develop my own brackets, but testing something like brakes on my own car seems slightly sketchy to me. If anyone else wants to take their life in their hands, I could do the CAD and probably get them machined
Also, in the interest of balance, and preserving bias, a rear kit would be appropriate. I do not see any solution for the rear set, so I emailed Godspeed to ask if they did anything for the 2 pots, but have no answer yet.
From googling around, it seems that Godspeed is on various subie forums and talks this kit up being better than the factory brembos. The kit seems to be comprised of a spacer for the caliper to accept the wider rotors, I assume (though do not see in pictures) some kind of bracket to work with the bigger diameter rotors, along with the rotors, and pads and whatnot. He claims the rotors are custom? Obviously this looks like it would only be fiscally reasonable for someone in the UK (maybe).
I am interested though because - barring any objections to the integrity of brackets and spacers - it would make a neat kit. Probably not interested in shipping the kit from the UK. Nor rotors every time I need to replace them. But I like the idea. Anyone have any thoughts? Or warnings? Or general "you're a noob / this is a dumb idea / you don't need a bbk" comments?
Cuchullain is offline   Reply With Quote
Old 06-03-2014, 11:01 AM   #121
gramicci101
Off Topic
Is their bracket meant to be used in addition to the 4 pot bracket, or will it replace the 4 pot bracket? If it's in addition, now you're stacking brackets on top of brackets, and that seems sketchy.
Custom rotors means big money every time you need to replace them. I'd get something with parts that are more commercially available, like brembo or AP racing.
Old 06-03-2014, 12:29 PM   #122
Cuchullain
Cuchullain's Avatar
I believe that the bracket replaces the original one. No way I would want to stack brackets.
As far as the custom rotors, I was kinda looking to see if there were any similar solutions that used a more standard size. Perhaps something with the STI rotor size.
I am thinking that I might get the brakes then take some measurements to see if I could make my own brackets. Not sure it's really feasible, but could be an interesting thought experiment anyway.
Old 06-03-2014, 12:35 PM   #123
gramicci101
Off Topic
A 2004 STi (5x100) uses 326x30 front and 316x20 rear rotors. I've been considering trying to make brackets to use the OEM calipers with those rotors, but I don't know if they'll clear a 30mm rotor width. AP Racing makes a 332x26 rotor, but they're $$$.
Old 06-03-2014, 12:59 PM   #124
Cuchullain
Cuchullain's Avatar
The way Godspeed worked the fronts is a spacer in the caliper itself. In theory, this sort of makes sense, the pistons don't have to travel any further, and the hardware might work. As far as making my own, the spacer for the caliper would be the easy part, and what I'd be lest concerned about breaking. The extended bracket is what I would be worried about, but as long as it has enough near on it it *should* hold up fine.
Old 06-09-2014, 07:55 PM   #125
RB Performance Brakes
RB Performance Brakes's Avatar
Drives: BRZ/FRS
For those of you planning on retro fitting or already have the WRX calipers.
RacingBrake offers Front Light Weight Two Piece Rotors for Subaru WRX
That will work with your FRS/BRZ Caliper swap.
FT86Forums member receive free shipping to the lower 48 states using coupon code FT86-SHIP
Reference Photo
RacingBrake Rotors feature 3 patented designs
  • Center Mount – Hat mounts onto the surface of the rotor ring, balancing stress load and improving cooling by allowing air flow to enter from both the inboard and outboard side of the rotor
  • Convergent Vane – Provides efficient air flow and temperature across the disc surface
  • Open Slot – Advantage of both drilled and slotted, optimizes the friction between pad and disc
Street and Track brake pads are also available for your WRX Calipers.
To learn more about us,
Visit our website at
www.RacingBrake.com
RB Performance Brakes is offline   Reply With Quote
Old 06-15-2014, 03:24 PM   #126
Andreas83
Andreas83's Avatar
Does any one know how these calipers are in regards of wheel clearance?
Better then sti brembo calipers?
I have a set of rpf1 17x9 et35.
Andreas83 is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 Premium Auto Styling Southern California 2 06-22-2012 07:34 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
