Old 01-01-2012, 07:29 PM   #113
Levi
Drives: Toyota
The MX-5 is mid-front engine. The AS1 not really.
Levi is offline   Reply With Quote
Old 01-01-2012, 08:46 PM   #114
fatoni
Originally Posted by NastyNate View Post
I concur. Although I could have given some indication of the ensuing sarcasm.
Even when I added a 70lb roll bar I couldn't tell a difference in handling. The biggest difference I will see is when I ditch the stock 17" boat anchors and go to a 15". I can do more there than worrying how much my fmic weighs and what fractions of a second it's slowing me down. Stock 17x7's weigh 18-19lbs each, while the 15x9's I want weigh about 13.5. 4.5 lbs of unsprung weight off each corner is gonna be nuts.
i was going to say basically all that if you were serious about the handling jazz. 6uls? with the rs3s on them the grip is just plain stupid
Old 01-01-2012, 08:46 PM   #115
fatoni
first, they are saying the as1 is fmr. second, that has literally nothing to do with adding weight in relation to changing the handling
Old 01-01-2012, 09:03 PM   #116
NastyNate
Drives: 05 MazdaSpeed Miata
Miata is 50/50 the FRS 53/47 weight distribution. Say a turbo kit adds a total 75lbs. The miata weighs 2500 and say the fra 2700. We'll split the difference and say 2600lbs. That means about a 3% increase of weight up front. So the frs goes to a 56/44 ratio. So drop 2 pounds of unsprung weight off the front and now you're back to stock. Nevermind you add a set of coilovers and do some corner weighting.
Fast in the straights is for everyone else. Fast in the corners is for me.
NastyNate is offline   Reply With Quote
Old 01-01-2012, 09:08 PM   #117
NastyNate
I want a set of nickel 6ul's but for the price I'm just gonna get the c3m in a 15x9 in black with 225/45/15 rs3's. Just for a bit of something different I may add silver rim stripes just to break things up a bit.
Old 01-02-2012, 12:36 PM   #118
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Meh, Motegi trak lites weigh 10 lbs a piece for 15x6.5... and R comps at that size are super cheap.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 01-02-2012, 02:06 PM   #119
fatoni
well of course a 6.5" rim is lighter than a 9" rim but even with street tires the 9" rim is going to be as fast if not faster
Old 01-02-2012, 02:09 PM   #120
fatoni
Originally Posted by lfawishes View Post
15's, good luck with that. Thats a good way to decrease handling, you may think your car is lighter and faster with unsprung weight but I'd bet money you are cornering at a slower max speed. Also 15's fit shite brakes.
Turbo can weigh about 18lbs, tmic-20lbs~
i dont know if you realize that this conversation was about a miata but 15s are the way to go, its been practically proven. also you should probably tell every f1 team that using 13s is only slowing them down
Old 01-02-2012, 02:55 PM   #121
Boxer 86
I ♥ My Spinning Triangles
Boxer 86's Avatar
Drives: 1989 Mazda RX-7 GTU
I'd much rather see four polished trumpets surging air from the atmosphere into the engine than a giant turbine shoving air down it's throat
Lover of true sports cars.
I drive an '89 FC, and wish to own a BRZ
Boxer 86 is offline   Reply With Quote
Old 01-02-2012, 05:11 PM   #122
NastyNate
Really? The entire Miata community would say otherwise, nevermind common sense.
I have shit brakes. Very aggressive pads, stainless lines, and ported/slotted rotors. At 40mph I can slam on the brakes and not activate the ABS.
Old 01-02-2012, 05:13 PM   #123
NastyNate
How much are the Motegis though? The c3m is about $100 a wheel.
Old 01-02-2012, 10:48 PM   #124
fatoni
Um actually that is not the case, if you mean spec miata where they use very slow basic cars then thats meaningless especially given they are a set size for all races no choice in spec. Also why the faster miata class does not use them, and the new ones don't have them stock.
The miata also 1)weighs MUCH less, 2)and is 20 inches shorter. 3)Many miatas are also UNDERPOWERED, they don't need the rubber for a variety of reason. Another being cheaper tires for track use. This doesn't mean they are the best handling.
Because one small car uses 15 they are the best for anything? Yeah thats why NO PERFORMANCE CARS COME WITH 15 inch Rims. LOLOL. Miata guys total authority.
youre wrong about a bunch of those points just so you know. the fastest miatas ive ever seen have ALL been running 15s not just slow spec miatas. these are the miatas that set all time miata track records. for miatas, they handle the best. thats been proven. the new miatas dont have 15s because they are based of the rx8 and there are clearance issues but that doesnt mean that its faster. i dont know why you think a 15" rim means less rubber. if anything it would be more rubber.
as far as this car is concerned nobody knows what is going to be fastest let alone clear but that was never the conversation. saying that no sports cars come with 15s means they arent fast is like saying that no sports car comes with a 4cyl boxer motor so the frs isnt a sports car. why do f1 cars run on 13s?
Old 01-02-2012, 10:55 PM   #125
NastyNate
So then do me a favor: google unsprung weight and tell why so many are so concerned about reducing it. Hell find me something that says you should increase or leave it the same. And while you're at it show me where I said miatas are the best handling.
And when does something coming stock with a certain item mean its the best?
No matter what, at the end of the day reducing unsprung weight is a very benficial thing. If it wasn't top race bodies down to grass roots racers wouldnt be concerned about it.
Old 01-03-2012, 01:02 AM   #126
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
About $210 ish a wheel. Forged too, really strong.
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 08:42 AM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 12:58 AM
Turbo or Suppercharger or none xc Engine, Exhaust, Transmission 12 11-17-2011 05:40 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
