Old 04-02-2014, 02:51 PM   #113
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
is this the only source of an OEM damper dyno?
Originally Posted by u/Josh View Post
Old 04-03-2014, 10:08 AM   #114
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
@Racecomp Engineering
@Shankenstein
Can you guys confirm that the information in the 1st post has been peer reviewed and can be taken as absolute fact, particularly the OEM weight distributions and motion ratios and damper travels.
Old 04-03-2014, 10:42 AM   #115
We posted one very early on, not in this thread but somewhere. It looks similar.
EDIT: it's in post one here.
I looked through everything on page 1 the other day (see when I caught a typo) and everything looks pretty good.
- Andy
Old 04-03-2014, 10:44 AM   #116
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
- Andy
thank you
if possible, can it be posted in its original medium (so that it could easily be overlayed over another graph)
Old 04-03-2014, 10:57 AM   #117
I'll see what I can do later today.
- Andy
Old 04-20-2014, 05:02 PM   #118
dezmoondo
dezmoondo's Avatar
Drives: Whiteout FRS
Originally Posted by pseudo View Post
Great looking thread, guys. Kudos to @Shankenstein for starting this and adding a lot of useful information.
I stumbled upon this while looking for a computational model of the BRZ suspension. I am a mathematician with a slight theoretical physics background and strong computer science skills. So not much engineering experience.
Does anyone have suggestions on a resource for rapidly learning the ME side of a good suspension setup? Specifically what the ultimate, theoretical goals of an ideal setup are, and the fundamental theory that drives suspension design. Books, technical papers, online articles, forum posts, etc would all be appreciated.
I would be happy to help out with this project once I get up to speed, looks like it's off to a great start!
You can read Tune to Win by Carroll Smith. There's a section for suspension geometry.
dezmoondo is offline   Reply With Quote
Old 04-21-2014, 09:41 AM   #119
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
@Shankenstein
The usual legal mumbo jumbo.
Shankenstein shall not be held liable for any personal or business decisions made using information supplied to this or any other website. Although Shankenstein may be a licensed engineer, Shankenstein has never been contracted by FT86Club or any other entity (private or public) to disseminate accurate information in this thread or others on this site. Any confidence in Shankenstein's posts should be tempered by the fact that Shankenstein is probably tired, daydreaming, at work, and/or drooling over build logs while posting.
That being said, the vast majority of the information has been read over numerous times by people smarter than me. It should be more accurate than most forum posts, if that counts for diddly squat.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
Wepeel (04-29-2014)
Old 04-29-2014, 11:44 AM   #120
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Well, i was simply hoping for more peer-editing
particularly when it comes to motion ratios. I've yet to find anyone diagraming the suspension piecemetal.
Two weeks ago i took apart the rear coilover and attached the damper back to the car without the spring.
I then took measurements of how much the wheel travelled vs how much the damper shaft travelled and got some wild results.
even accounting for measurement error, i could not get close to the 0.75 figure ( was averaging around 0.85 ish).
Furthermore i would get different results depending on where along the path i measured. Full droop to oem height i averaged around 0.9.. from OEM height along about 1.5" of compression i averaged 0.80ish (need to check my notes, its been two weeks)
now i'm curious...
The Following User Says Thank You to 7thgear For This Useful Post:
Shankenstein (04-29-2014)
Old 04-29-2014, 12:01 PM   #121
Wepeel
Drives: '13 BRZ Ltd
now i'm curious...
This is the best way to do it. And yes, it will change throughout the range - it's mostly relevant at ride height +/-[however much travel you expect to see]. So maybe +/- 1". The motion ratio will be greatest (i.e. greatest difference between wheel travel and shock travel) when the lower arm is near horizontal, which is near reasonable ranges of ride heights, so your numbers make sense, should be close to the "analytical" MR of 0.78 that I measured (you said 0.80ish, I'd be interested to see your exact numbers, but I'd say that's pretty close).
Did you do the same thing for the fronts?
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Old 04-29-2014, 12:09 PM   #122
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
hoping will have time to do the fronts next week. I can only work at my parents place because i am forbidden to do car work at my apartament.
This was my first time taking apart the FRS suspension components so it took longer than anticipated. The Strutted impreza and also my old VW were much, much easier.
Old 04-29-2014, 12:51 PM   #123
As Wepeel said it does change throughout the range.
0.8 is very close at ride height. 0.75 in that thread is not exact, I meant it to be a simplified example. I should have mentioned it was not exactly 0.75 in retrospect.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
7thgear (04-29-2014), Shankenstein (04-29-2014)
Old 04-29-2014, 03:45 PM   #124
Shankenstein
Frosty Carrot
now i'm curious...
The feedback is much appreciated. I've added the following:
Rear = 0.85 (at full droop) to 0.83 (at stock height) to 0.80 (compressed to bumpstops)
Since I can't vouch for the accuracy of either you or RCE, I split the difference and tried to make it clear that the value changes. Constants are for suckers anyways.
Old 04-30-2014, 09:00 AM   #125
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
accordinging to my notes, 0.8~0.82 motion ratio from OEM heigh through ~31 mm of damper shaft compression in the rear
also if i was to eyeball it i would say the rear bumpstops are engaged after about 8-9mm of compression... yikes.
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
Shankenstein (05-06-2014), Wepeel (04-30-2014)
Old 05-06-2014, 05:53 AM   #126
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
subbed, good stuff. Thanks for posting.
jeepmor is offline   Reply With Quote
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 02:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
