| View Poll Results: ? | |||
| SC |
133 | 38.33% |
| TC |
159 | 45.82% |
| NA |
55 | 15.85% |
| Voters: 347. You may not vote on this poll | |||
#113 |
Site Moderator
Drives: ichi 86 Project
Hey those thing do have punch! iirc there were some youtube vid on NA vs leaf blower
#114 |
Drives: 1996 RAV4
Why not go absolutely crazy and use both?
#115 |
Site Moderator
Did I heard both?
Like this? ![]() ![]() ![]() ![]() ![]() wanna read more here's the thread http://forums.nasioc.com/forums/show....php?t=1688562 |
#116 | |
Drives: 2013 BRZ / 2015 WRX
(Noting that, if I recall properly, he was running nigh 600 hp) |
#117 | |
Site Moderator
How bout this one? Do you remember this one? Twin Turbo Supercharged ![]() ![]()
#118 | |
Kuruma Otaku
Because titanium. |
#119 | |
I wonder if it's similar to the first one you posted, in that the setup is SC > TC and not compounding. Yep, exactly! The best example of this I've seen was a Mini S (older SC'd one) build by a guy Hubie Fuh, featured in Sport Compact Car a while back. As well as the feature, there was an interesting Dave Coleman editorial / technical article on it. Basically, it was easier and more efficient to compound-charge the Mini by adding a small turbo and routing it with the stock supercharger than try to spin it way out of its efficiency range to up the boost. I believe there was a similar setup available for the first-gen MR2s that were supercharged, to twin charge. But, especially with new supercharger and turbocharger technology and the perils of modern engine management tuning, I'd shy away from twin-charging, stock or aftermarket. There should be enough room under the hood to have fun, with the little flat 4 (which should be far back towards the firewall). |
#120 |
Site Moderator
iirc it should be compounding
#121 |
Drives: D31a
What is the point of that though? Couldn't you just turn up the loud button on the turbo alone and get the same effect? I understand the bypass version, but the compound version doesn't make sense.
#122 | |
Kuruma Otaku
Stage two is once the turbo spools, feeds into the supercharger, gets compressed again, then enters the intake. This creates massive intake pressure, and since the turbo doesn't even have to be that big, very quickly. Size matching them is apparently a little complicated though. Diesel trucks can do it with small and big turbos.
Because titanium. |
#123 | |
Site Moderator
#124 | |
Drives: D31a
#125 |
Drives: 2002 honda civic ex
#126 |
RaggedEdge Autosports
Drives: 97 APU Supra
Just look at what Subaru has done with there turbo boxer platforms in the impreza's, hope they continue the tradition
| Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) — General Topics | 118 | 11-16-2017 02:19 PM |
| 2L turbo exiga. | 86Fan | Engine, Exhaust, Transmission | 16 | 06-26-2010 06:36 PM |
