View Poll Results: ?
SC 133 38.33%
TC 159 45.82%
NA 55 15.85%
Voters: 347. You may not vote on this poll
Old 08-25-2010, 10:39 PM   #113
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by GenkiElite View Post
Duct tape and a leaf blower ftw.
Hey those thing do have punch! iirc there were some youtube vid on NA vs leaf blower
Old 08-26-2010, 03:37 PM   #114
djohnson
Drives: 1996 RAV4
Why not go absolutely crazy and use both?
djohnson is offline   Reply With Quote
Old 08-26-2010, 03:55 PM   #115
ichitaka05
Site Moderator
ichitaka05's Avatar
Did I heard both?
Like this?
wanna read more here's the thread
http://forums.nasioc.com/forums/show....php?t=1688562
Old 08-26-2010, 06:24 PM   #116
bigbcraig
Drives: 2013 BRZ / 2015 WRX
Did I heard both?
Like this?
Yes, but this isn't really twincharging. He does not compound the boost, i.e. running thru supercharger and then turbo; rather he uses the SC until the turbo spools, at which point the SC is bypassed and its clutch releases. It's a highly over-engineered way to mostly eliminate lag, not a madman making insane amounts of power with compounded induction.
(Noting that, if I recall properly, he was running nigh 600 hp)
bigbcraig is offline   Reply With Quote
Old 08-26-2010, 08:43 PM   #117
ichitaka05
Site Moderator
ichitaka05's Avatar
True 640hp iirc.
How bout this one? Do you remember this one? Twin Turbo Supercharged
Old 08-26-2010, 08:44 PM   #118
Dimman
Kuruma Otaku
Dimman's Avatar
This is what you're talking about for real twincharging.
Because titanium.
Old 08-26-2010, 11:37 PM   #119
bigbcraig
True 640hp iirc.
I know I've seen that twin turbo / air filters in the hood setup... but not with a supercharger too! o.O
I wonder if it's similar to the first one you posted, in that the setup is SC > TC and not compounding.
Yep, exactly! The best example of this I've seen was a Mini S (older SC'd one)
build by a guy Hubie Fuh, featured in Sport Compact Car a while back. As well as the feature, there was an interesting Dave Coleman editorial / technical article on it. Basically, it was easier and more efficient to compound-charge the Mini by adding a small turbo and routing it with the stock supercharger than try to spin it way out of its efficiency range to up the boost.
I believe there was a similar setup available for the first-gen MR2s that were supercharged, to twin charge.
But, especially with new supercharger and turbocharger technology and the perils of modern engine management tuning, I'd shy away from twin-charging, stock or aftermarket. There should be enough room under the hood to have fun, with the little flat 4 (which should be far back towards the firewall).
Old 08-27-2010, 12:43 AM   #120
ichitaka05
Site Moderator
ichitaka05's Avatar
iirc it should be compounding
Old 08-27-2010, 01:02 AM   #121
Franisco
Franisco's Avatar
Drives: D31a
What is the point of that though? Couldn't you just turn up the loud button on the turbo alone and get the same effect? I understand the bypass version, but the compound version doesn't make sense.
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 08-27-2010, 01:34 AM   #122
Dimman
Kuruma Otaku
Dimman's Avatar
Stage one boost is instantly on from the positive displacement supercharger.
Stage two is once the turbo spools, feeds into the supercharger, gets compressed again, then enters the intake. This creates massive intake pressure, and since the turbo doesn't even have to be that big, very quickly.
Size matching them is apparently a little complicated though.
Diesel trucks can do it with small and big turbos.
Because titanium.
Old 08-27-2010, 01:45 AM   #123
ichitaka05
Site Moderator
ichitaka05's Avatar
size matching isn't the problem. How much air goes into SC & TC is the problem (PSI).
Old 08-27-2010, 02:05 AM   #124
Franisco
Franisco's Avatar
Drives: D31a
Hm, interesting concept. I'd see that as being a reliability nightmare though
Old 08-27-2010, 11:47 AM   #125
MtnDrvr86
Drives: 2002 honda civic ex
Volkswagen has been doing it for a few years from the factory on their 1.4 TSI. Its won a few awards aswell
MtnDrvr86 is offline   Reply With Quote
Old 08-27-2010, 01:25 PM   #126
BoostJunkie
RaggedEdge Autosports
BoostJunkie's Avatar
Drives: 97 APU Supra
Just look at what Subaru has done with there turbo boxer platforms in the impreza's, hope they continue the tradition
BoostJunkie is offline   Reply With Quote
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku BRZ First-Gen (2012+) — General Topics 118 11-16-2017 02:19 PM
2L turbo exiga. 86Fan Engine, Exhaust, Transmission 16 06-26-2010 06:36 PM
